Hurth transmission issue
- Helmsman
- Has thanked: 73 times
- Been thanked: 42 times
Re: Hurth transmission issue
- Has thanked: 468 times
- Been thanked: 1765 times
- Helmsman
g36 wrote:Source of the postNharrison5 wrote:Source of the post Viper, I live on Lake Chickamauga
sorry to hijack but i also am on lake chickamauga at pine harbor didnt realize i had any carver friends so close
Sent you a PM
- Helmsman
- Helmsman
Boat now travels fine. Though we still have the leak.
Next step is to do the same with the starboard.
My opinion is that we got tranny fluid on the seal in the Tidesmarine sure seal and caused that to start dripping. Will have it pulled after the Memorial Day rush to have fixed if moving it doesn't fix.
Nharrison5 wrote:Source of the post ....It was actually the zf63a transmission filter....
That's a new one for me. Never had a tranny filter that bad that it would cause the symptoms you described. Thanks for the followup.
- Helmsman
To recap, there were three issues.
1) the water fuel separator had water in it. Changed that out and it stopped the rpm "dance".
2) the transmission fluid filter was replaced. Cleaned the old one to use as a spare.
3) the dripless shaft seal still leaks. I moved it around some and then tightened the 5 nuts around the seal. They were pretty loose. The water appears to be coming from the seal. When I take the boat out this weekend, I will see if that stopped the leak.
I will be pulling the boat for service as soon as the boat yards free up from their Memorial Day crush and will replace both drip seals then.
Any opinion from anyone on whether to stay with Tides Marine, go to the old style packing, or trying PSS?
- Helmsman
1) pulled the prop in the water. Prop was ok. Cleaned the transmission filter. That resolved the problem. Easiest things first, huh? When I returned home, I put a new filter on, re-cleaned the old for spare use, and changed the transmission fluid. Have not taken it out since but plan to this weekend.
2)the shaft seal is still leaking. I moved it around and tightened all nuts around the seal. They were loose. I will see if that fixes it until the boat yards free up and I can get the seals replaced.
3) mentioned above (I think) but replaced the fuel water separator filter and that fixed the "dancing" rpm issue first described.
Added both to maintenance schedule for each spring.
Thanks for the assists!
- Helmsman
Maintenance is key, as they say....
