my husband and I purchased a 1999 Carver 356. I feel like I'm pretty boat smart but this has me stumped. He is out of the country this summer and I decided to do some good spring cleaning. While cleaning the aft air conditioning ventsp I noticed the holding tank is full. Maybe 2 to 3 inches from the top. This explains A LOT since this is not our first Carver and our old Carver only had 1 tank that we didn't pump out more than about once a month. This boat is always full of Poo! I went back to the pump out station and pumped both tanks. I stopped several times to get the system to build up more suction but it seems like it is empty. When I go look however it is far from empty! I looked all through the mounds of paperwork that came in the Carver "suitcase" but all of the diagrams and schematics are on the 355 model and don't look anything like our layout. I was thinking of reasons this might happen and all I can come up with is thAt maybe the vent is blocked. Wouldn't the vent need to be open to suck out the poo? Doesn't air have to replace the contents? I looked for the air vent for the tank but I'm not sure which one it is? I tried to look for the air vent by following it from the tank but wow that space is small. The holding tank is literally an inch from the air return Everything else works fine with the sanatation system. Thanks for any thoughts. It's a gross thought to have so much crap in the boat that I can't get rid of!Welcome to Carver Yachts Owners Forum
Holding tank
- Roxanne
- Vessel Info: 1999 Carver 356
- Has thanked: 13 times
- Been thanked: 10 times
Holding tank
my husband and I purchased a 1999 Carver 356. I feel like I'm pretty boat smart but this has me stumped. He is out of the country this summer and I decided to do some good spring cleaning. While cleaning the aft air conditioning ventsp I noticed the holding tank is full. Maybe 2 to 3 inches from the top. This explains A LOT since this is not our first Carver and our old Carver only had 1 tank that we didn't pump out more than about once a month. This boat is always full of Poo! I went back to the pump out station and pumped both tanks. I stopped several times to get the system to build up more suction but it seems like it is empty. When I go look however it is far from empty! I looked all through the mounds of paperwork that came in the Carver "suitcase" but all of the diagrams and schematics are on the 355 model and don't look anything like our layout. I was thinking of reasons this might happen and all I can come up with is thAt maybe the vent is blocked. Wouldn't the vent need to be open to suck out the poo? Doesn't air have to replace the contents? I looked for the air vent for the tank but I'm not sure which one it is? I tried to look for the air vent by following it from the tank but wow that space is small. The holding tank is literally an inch from the air return Everything else works fine with the sanatation system. Thanks for any thoughts. It's a gross thought to have so much crap in the boat that I can't get rid of!- mjk1040
- Been thanked: 248 times
Re: Holding tank
Re: Holding tank
A venting issue is a possibility. If you have an overboard discharge option, some are plumbed in a way that incorporates a 3-way valve in the output side of the tank. If this is the case with you and the valve is switched to the overboard side, you won't be able to pump it out through the deck fitting.
Have you confirmed there actually is waste in the tank and that you're not simply looking at a sludge build up on the tank walls?
- Has thanked: 602 times
Re: Holding tank
- Roxanne
Re: Holding tank
- Samuel
- Has thanked: 1 time
Re: Holding tank
help you.
- Samuel
Re: Holding tank
- Roxanne
Re: Holding tank
- Roxanne
Re: Holding tank
- Roxanne
Re: Holding tank
