Carver 400 MY engine RPM issue
- Been thanked: 601 times
Re: Carver 400 MY engine RPM issue
- hausherrs
- Vessel Info: 1996 Carver 400
- Has thanked: 5 times
- Been thanked: 10 times
Tank is full so I have to get out the ole shop-vac and vacuum out the fuel. IM KIDDING!
Anyone have recommendation on rubber gasket material that is resistant to ethanol?
- cpoint
- Has thanked: 208 times
- Been thanked: 31 times
- Has thanked: 78 times
- Been thanked: 1093 times
- cpoint
- cpoint
km1125 wrote:Source of the post A friend of mine has a 356 with 8.1's and he has had to frequently change the small filter on the engine. He keeps spares aboard and has even changed them enroute while someone else mans the helm with just the other engine providing revolutions.
That sample to change, where is it located (I mean the filter)?
- cpoint
Now when I get near 3000 rpm I get tach fluctuation. even if I replace the filter now. So I am thinking if there is an inline fuel filter, and some stuff reached it through water seperation filter, may be causing the problem. I just want to confirm that before I call the guys back that filtered my port tank.
Thanks all.
- Has thanked: 64 times
- Been thanked: 481 times
- cpoint
waybomb wrote:Source of the post Put your hand on the fuel line and follow it back to the tank. If there's a filter there, you'll run into it. The PO may have even installed one after the fact.
Thanks, will take a look this weekend. I looked at oll manuals I found online, and can't tell where the OEM has it if there is one on 2000 model.
