Walter V-drive Question
- amanphoto
- Has thanked: 3 times
- Been thanked: 12 times
Thanks for your help.
- Has thanked: 602 times
Re: Walter V-drive Question
- SanJuanDreamer
- Has thanked: 1 time
- Been thanked: 21 times
- SanJuanDreamer
Check the model number and look up the service manual for the drives too...
- amanphoto
- amanphoto
Recommended oil: SAE30 Heavy Duty Motor oil, Exxon Spartan EP-68 Gear oil or APG-80 Gear oil. Don't use multi grade motor oils.
amanphoto wrote:Source of the post There is a tag on the V-drive. It says model RV-10 - RV-50 use SAE30 or EP-66 Gear Oil. Models RV-61 - RV-91 use APG80. It recommends some other oils but its hard to read. It is on a 1998 Carver Mariner 350 with 454 engine.
Yep, totally different setup than mine , I have small block mercs.......by the looks of it you have it covered....I would hazard a guess here and say that if you do not see oil in the bilge then the cooler ,if you have one, would be the place to start....
- amanphoto
