Engine alignment (left to right) - Mariner
- amanphoto
- Has thanked: 3 times
- Been thanked: 12 times
I have a Mariner with a velvet transmission and direct mount Walter v drive. I can not turn the propeller shafts by hand. I'm assuming the engines need alignment.
- Has thanked: 469 times
- Been thanked: 1765 times
Re: Engine alignment (left to right) - Mariner
What makes you think it's out of alignment? Is there a vibration? Have you unfastened the coupler from the tranny flange and taken proper alignment measurements before you move the engine?
Have you first checked to ensure the running gear is properly aligned; ie strut is properly aligned with the shaft tube through the hull?
Where are you trying to turn the shafts from, inside the boat or outside? From the inside is not easy to do.
- amanphoto
There is the same boat at the marina and I checked the shaft rotation on his boat. Also when I had the boat inspected they mentioned they might need to be aligned. My shafts have different tension between the two of them. One is has a lot of tension and the other has little.
- mjk1040
- Been thanked: 246 times
Users browsing this forum: No registered users and 52 guests
