Well that escalated quickly!
- Been thanked: 654 times
Re: Well that escalated quickly!
- Jlubas
- Vessel Info: 1995 Carver 355 Aft Cabin
Crusader 454 XLI's
- Been thanked: 491 times
Some call those, generically, Racor.
Typically an oil filter looking device with a screw on bowl to catch water on the bottom.
Sometimes that bowl is clear plastic, sometimes metal.
- SanJuanDreamer
- Has thanked: 1 time
- Been thanked: 21 times
On my 98 454xLi, there are three on each engine. The Oberg filter, Racor 110 fuel\water filter and the barrel fuel filter.
Start with finding and cleaning\replacing fuel filters.
- Roxanne
- Vessel Info: 1999 Carver 356
- Has thanked: 13 times
- Been thanked: 10 times
Roxanne wrote:Source of the post
The starboard engine runs 180-200F. We've replaced the impeller and brought the temp down.
When you "brought the temperature down", did it get down to 180-200, or is it now closer to 160?? (later you say 'engines are running 160 or below').
These are all EFI engines right?? They should not really have vapor lock as the gas is under pressure... different from a carb system where there is little pressure and a vacuum pulling fuel from the tank. Perhaps you have leaking pressure regulators?? Did you ever check fuel pressure on the rail after the engine is shut down?
km1125 wrote:....These are all EFI engines right?? They should not really have vapor lock as the gas is under pressure... different from a carb system where there is little pressure and a vacuum pulling fuel from the tank.....
Not necessarily true. Even on EFI, you can get vapour lock. There's already a vacuum on the suction side of the fuel delivery system which is a contributor to vapour lock. Under normal operating conditions, the amount of vacuum isn't enough to cause the problem, but add enough heat, and the combination of the two on that side will cause issues, hence the introduction of liquid cooled fuel systems like Cool Fuel on Merc EFI apps.
Vapour lock has some very definite symptoms. If the symptoms don't meet the criteria, it's likely not vapour lock but something else. And a hot running engine doesn't necessarily mean you'll have vapour lock or that your engine compartment temps will reach unacceptable levels. Some engines run with 180* stats. I wouldn't say it's a Merc 454 problem. Under the right conditions, it'll happen with any brand. You'll just read more about the Merc 454 because there's more of them out there than all the other brands combined!
I suspect that many of these problems would be traced to defective pressure regulators or a problem in the cool-fuel system.
If I had an engine that might be susceptible to a vapor lock condition, I'd consider adding a return fuel line to the tank, or a low pressure pump just after the anti-siphon valve. Maintaining even a slight pressure in the system is one of the big keys into stopping the fuel from vaporizing, just like a radiator cap stops the coolant from boiling.
- mjk1040
- Been thanked: 248 times
Users browsing this forum: No registered users and 9 guests
