Holding tank
- cpoint
- Has thanked: 208 times
- Been thanked: 32 times
Re: Holding tank
- Reelpriority
- Vessel Info: Carver 356 Aft Cabin
1999
Miss Judy, Murrells Inlet, SC - Been thanked: 4 times
Re: Holding tank
The 18 gallon aft holding tank is under the pull up carpet and floor board adjacent to the aft head door. Check the level with a flashlight. I assume you do not have the green, Amber, and red lights located n the head that alerts you to the holding tank fill levels.
Murrells Inlet, SC
- Roxanne
- Vessel Info: 1999 Carver 356
- Has thanked: 13 times
- Been thanked: 10 times
Re: Holding tank
and see if I can clean off the connectors. When I unscrewed the main lid there is a tough plastic or rubber lining over it. It doesn't seem to be removable. If you are as old as I am you will remember Coke use to Come in a glass bottle. When you popped the metal top off there was a plastic lining in the lid. It reminds me of that only much thicker. Is that something that is lining the tank for a reason? Can I cut it out or try to remove it. The tank is such a tight fit in that compartment I sure don't want to mess it up. I cannot imagine replacing it!!- Roxanne
Re: Holding tank
- nightsky
- Vessel Info: '94 Carver 390 cpmy
- Has thanked: 6 times
- Been thanked: 16 times
Re: Holding tank
Roxanne wrote:Source of the post About the green, amber level lights. Ours seem to be stuck or more like dirty? After we pump out we get a green. After a day we're at half. That's where it stays. When working on the front tank I was able to pull out and clean off the sensors. The back tank is so tight in that space I can barely reach the cap. I know it's several inches long and because of the space even if I unscrew it I would never be able to pull it up. There might be 2 inchs of space above it. I thought I might unscrew the other tank lid and reach through the tankand see if I can clean off the connectors. When I unscrewed the main lid there is a tough plastic or rubber lining over it. It doesn't seem to be removable. If you are as old as I am you will remember Coke use to Come in a glass bottle. When you popped the metal top off there was a plastic lining in the lid. It reminds me of that only much thicker. Is that something that is lining the tank for a reason? Can I cut it out or try to remove it. The tank is such a tight fit in that compartment I sure don't want to mess it up. I cannot imagine replacing it!!
Roxanne that hard plastic under the main lid will have to be cut away. If you can, cut it as close to the threaded wall to have the largest opening possible. Take care not to damage threads. This should allow just enough room to stick a garden hose nozzle in to spray wash the sludge along the walls.
- Roxanne
Re: Holding tank
- Reelpriority
1999
Re: Holding tank
Murrells Inlet, SC
- Roxanne
Re: Holding tank
oh my gosh- Lyndon670
- Has thanked: 124 times
- Been thanked: 140 times
Re: Holding tank
http://www.camco.net/product/tornado-ro ... ser-10049/
2000 Carver 506
FOXY JOE
Volvo 7.4TAMD
Queens Cove Marina
Georgian Bay, Ontario
- Been thanked: 654 times
Re: Holding tank
https://accessories.lazydays.com/valter ... oCajHw_wcB
http://www.rvpartscountry.com/MasterBla ... kWand.html
d
