396MY Tv Coax routing
- Lou Skyking
- Vessel Info: 2000 396MY
- Been thanked: 4 times
- mjk1040
- Been thanked: 248 times
Re: 396MY Tv Coax routing
- Been thanked: 654 times
- Lou Skyking
and x2 on the "digital antenna' comment. You do not need a "digital" antenna to pick up broadcast signals... the antennas are functionally the same from analog to digital.
also my oem wiring and splitters and antenna booster all terminated behind the salon tv. found this when replacing that tv , you may check behind that tv or other for a access hole or panel
- Lou Skyking
- Reelpriority
- Vessel Info: Carver 356 Aft Cabin
1999
Miss Judy, Murrells Inlet, SC - Been thanked: 4 times
We never used the original air antenna. Removing the old technology A/B switch made sense. Clear HD signal now on three TVs.
Murrells Inlet, SC
- MeredithRaymond
- Vessel Info: 1998 Carver 355 Aft Cabin
- Has thanked: 3 times
- Been thanked: 5 times
- Contact:
mjk1040 wrote:Source of the post The 355 MY has a box located in the aft berth closet by the door entering the aft cabin, maybe the 396 MY has the same? And the original TV antenna maybe analog and not digital and that would explain none of the TV's work?
We have the switch in the same spot. Can you tell me where your cable connection from the dock to the boat is located? We are still trying to find ours. We currently have the coax cable running from the dock box to the fly bridge where the old satellite cable is located. There's got to be an easier port to access.
This is my first boat!
