Carver 356 aftcabin swim platform davit question
cpoint
Has thanked: 208 times
Been thanked: 32 times
Re: Carver 356 aftcabin swim platform davit question
Postby cpoint » April 13th, 2017, 10:43 pm
Elliott wrote:Source of the post I could use your help on two separate counts. The first is easy. How do I post a question or a topic on this site, if I am not replying to anything. I can not find any button that says post new topic, or something like that.
2
As I am far from my boat, I can not measure this. How high (in inches) is the top of the swim platform from the water.
I am thinking of making my own flip davits and I want to know if it will be too high to pull a boat up sideways.
Find the section you want to post to and you will see a button to post to topic, see attached. I pointed with red arrow, to post a new topic
cpoint
Postby cpoint » June 30th, 2017, 12:57 am
cpoint wrote:Source of the post
2
Eliott,
Sorry I am getting ready to tackle my davit issue, and just noticed I answered your #1, but overlooked #2. In any case if you still need the info, I believe my 356 is 15 iches from water level to top of the swim platform.
cpoint
Postby cpoint » July 2nd, 2017, 11:49 pm
finally got around looking at the swim platform today. Not bad as I though, I think I can finally finish the davit issue. I am attaching the images of the inside of 356 aft cabin swim platform. You remove the drawer from the back (next to bed), and this is what you see. Granted I can't reach with my arm to plate back the davit that I will be screwing from top of platform, I think I can use a long stick or something. Actually I can put a 2 x 6 x 6 under and just use stainless still screws to drive into the the wood under the platform. Easier then dealing with machine screws and nuts. Anyway I will try to take pictures as I do it and post here if it helps anyone.
cpoint
Postby cpoint » July 2nd, 2017, 11:52 pm
Actually I just came up with a brilliant plan in getting this done. I will take step by step pictures of what I do later this week in installing, that may help some one else. :approve:
cpoint
Postby cpoint » July 5th, 2017, 10:35 am
By the way, the handle (bottom seen in the above photos) is cracked and water is getting (dripping) inside. Does anyone know a exact size replacement? I checked everything online, can't seem to find one. I guess last resort would be to epoxy if I can't find it.
cpoint
Postby cpoint » July 5th, 2017, 10:39 am
cpoint wrote:Source of the post looks like I had a picture of what I am talking about after all. there are 6 screws in swim platform (shown with red arrow), what are these holding?
Update on this picture. The screws are holding nothing, there is no plate under. They are 1/2 inch screws, just screwed in the platform. Don't even go all the way through. But they allowed the area around the screws to get soft from moisture I guess. Not sure why they were there. Maybe previous owner started on a dinghy davit project and changed their mind :-(
Users browsing this forum: MrMojoRisin and 61 guests
