Carver 400 MY engine RPM issue
hausherrs
Vessel Info: 1996 Carver 400
Has thanked: 5 times
Been thanked: 10 times
Re: Carver 400 MY engine RPM issue
Postby hausherrs » July 3rd, 2017, 2:17 pm
cpoint wrote:Source of the post And fuel tank issues with crap in it, that seems to still be there...
May be worth looking into:
http://www.jegs.com/i/Oberg-Filters/706/8028T/10002/-1
Postby bud37 » July 3rd, 2017, 2:18 pm
Heh Steve you may have hit upon it , those hoses will go bad inside out ( delaminate ), all looks fine on the outside .....as far as any help, you need to hire ET, just the right height with really long arms and works for Reeses.... :-D ....good luck with it....... :beergood:
hausherrs
Postby hausherrs » July 4th, 2017, 12:03 am
Thanks bud. I got it out! I'm going to be hurting tomorrow. The hose is dated 1995.
hausherrs
Postby hausherrs » July 4th, 2017, 12:05 am
Been thanked: 248 times
Postby mjk1040 » July 4th, 2017, 7:18 am
WOW! Glad you found this! Your rough running issues may have become a serious issue of another nature real fast. May I suggest checking the entire fuel supply lines. Good Luck!
Postby km1125 » July 4th, 2017, 7:35 am
Are you able to purchase the pre-manufactured line like that or are you having to have one made?
I have similar crimped lines on my boat and was going to replace the fuel lines. Where would one go to get them crimped like this? It might be just esthetic, but I like these crimps better than the ring crimps and much better than putting on hose clamps.
Is there a name for these crimps?
Postby bud37 » July 4th, 2017, 8:18 am
KM1125.......try hydraulic guys that make up equipment hoses etc....
hausherrs
Postby hausherrs » July 4th, 2017, 5:16 pm
km1125 wrote:Source of the post Are you able to purchase the pre-manufactured line like that or are you having to have one made?
I ordered the crusader originals. But because of the holiday probably won't ship until tomorrow. I went to west marine and bought hose and made a temporary replacement. So I'm running again while the factory stuff comes in. I bought two because I'm going to replace both. That fitting ripped right off easily. I've had crimps like that done at a shop before. They were weak and leaked. Try to spin the hose at the crimp connector. It shouldn't spin. If it spins it'll probably leak.
Going to take it out for a test run shortly.
hausherrs
Postby hausherrs » July 4th, 2017, 5:18 pm
Here's where I hunt for part numbers:
http://www.marineparts.com/mpf/mpf70.aspx
hausherrs
Postby hausherrs » July 5th, 2017, 8:59 am
mjk1040 wrote:Source of the post May I suggest checking the entire fuel supply lines.
I took it out for a run yesterday and its not resolved. Its running worse. The engine stalled several times right as I was backing it into the slip. And it was windy so that was not fun. Ran my swim platform into a post and cracked the gel coat. Another new problem thats way low in the list!
I have a fuel pump ordered along with the factory hoses. My current fuel pump looks like a cheap knock off. Today I will be checking the anti siphon and the breather tube. And I might go hunt for a fuel pressure guage today just to see what it looks like.
Between the wind and white caps its not fun going on test runs with a failed engine.
Thanks,
Steven
