Both shore power circuit breakers went bad?
- dsolo
- Vessel Info: 1997 Carver 405 MY
454 EFI Crusaders
Name: La Belle ll - Location: Onekama, Michigan
- Has thanked: 68 times
- Been thanked: 25 times
Vessel "LaBelle"
1997 Carver 405 MY
454 EFI Crusaders
- Has thanked: 602 times
- Been thanked: 1310 times
Re: Both shore power circuit breakers went bad?
- dsolo
454 EFI Crusaders
Vessel "LaBelle"
1997 Carver 405 MY
454 EFI Crusaders
- mjk1040
- Been thanked: 248 times
- dsolo
454 EFI Crusaders
Vessel "LaBelle"
1997 Carver 405 MY
454 EFI Crusaders
dsolo wrote:Source of the post That could be the case. I had a tech working on the generator today. It is running and stopping quickly. He has a tech call into the tech support with the manufacturer.
Well theres your problem, It was hard to believe both breakers would go bad at the same time.........open the breaker on the gen. itself and see if you can power up then.
- mjk1040
It sounds like you have made certain you have 110 at the boat end of the cords and the wiring from the inlet plugs to the breakers are good?
- dsolo
454 EFI Crusaders
Guys I need to know how these breakers fried? I don't want to replace them to only fry another batch.
I am in Leland township harbor. I discovered the toasted breakers here after connecting the shore power. I saw 120vac at the panel for a short time. It then went to zero voltage. The dock attendant stated the shore power I plugged into did not work? He switched the power source to a nearby terminal. It is the terminal I verified had 120 volts at the boat.
So I have two possibilities, Genny back feed, witch I eliminated the circuit by turning the generator breaker off. Made no difference.
Now, how could a bad voltage at the shore power terminal fry the boat breakers?
Dan
Vessel "LaBelle"
1997 Carver 405 MY
454 EFI Crusaders
