1985 3607 Aft electrical problems
- rvance
- Vessel Info: 1985 3607 Aft Cabin
I have 12v breakers on top then 120 that runs my outlets, water heater, stove and they work fine.
I had to bottom panel meter showing no power but when I test it is does have power. My air (aft and Solon, and water pump) does not work but my front ac is working but no water. When i turn it on my top meter jumps. Everything worked correctly when the generator is on but now my gen wont stay running unless I hold the start on. It is no longer putting ele out. I did accidentally hit one of the power and ground wires together and don't know if that did something to my generator. Any ideas what my problem is?
- Has thanked: 78 times
- Been thanked: 1093 times
Re: 1985 3607 Aft electrical problems
I have the same boat, but no generator, so I'm not sure how your switching for generator vs shore power is setup. A picture or two would help.
If you have A/C, then you have two shore power inputs, correct? Do they have a separate set of meters for the second shore power input?
Do you have one water pump for all your A/C units or is there a dedicated one for the v-berth unit?
You may have tripped your main breaker out of the generator. That should not have prevented you from using shore power for everything though. I would think the generator would still run but just not deliver power.
- rvance
Ahhh.. that might be a clue. Are you saying the last breaker is a two-pole breaker?
Your mains should be two-pole breakers, switching both the neutral and hot. Ground should never be switched. The neutrals should not be connected between your two shore power inputs, but when they are both connected to the generator, then they can be. The gen/shore switch should take care of that. Sounds like you might have relays on the genset that takes care of the switchover.
Sounds like you have a problem with the neutral conductor somewhere... either one of the breakers isn't passing it or there is a bad connection... which could be in the relays too.
- rvance
And I said a NEUTRAL issue, not a ground issue. While sometimes similar or at the same potential, they are NOT the same thing. Very serious safety issues arise when those two get confused or miswired.
- rvance
- rvance
- Agriman
- Vessel Info: 1998 Carver 350 Mariner Twin 454 Crusaders
- Has thanked: 5 times
- Been thanked: 5 times
Hope this helps.
- Has thanked: 598 times
- Been thanked: 1281 times
rvance wrote:Source of the post OK I have the breaker panel fixed and power to everything. While I was working on it i did cross a hot and ground and it sparked a bit. But when I was done, My generator wont stay running only if i keep it on start. It is not putting power out. Any ideas?
Could be a few things perhaps related to your quick short...I know this is an older model but hopefully it will be this way.....but anyway, try this.....on your gen itself may be a breaker ,if there is, open the breaker and try to start that way, with the breaker open only the gen engine should run , it will not make any electrical power.Before you do that though have a look on that panel on your gen and see if there are some fuses there ( check them if there are ).Good luck....
