Noise above 2600 rpm
- crquisto
- Vessel Info: 2000 Carver 406 Aft Cabin, twin 7.4 gas Mercruisers - Flyboy II
- Has thanked: 2 times
- Been thanked: 3 times
- mjk1040
- Been thanked: 248 times
Re: Noise above 2600 rpm
- John Easley
- Vessel Info: Sold a 1986 42' Chris Craft Catalina. Looking for a 1999-2006 530 Voyager Pilothouse.
- Has thanked: 5 times
- Been thanked: 8 times
mjk1040 wrote:Source of the post My guess would be something is not true in the output shaft from the transmission to the prop. Shaft log maybe. If access is good one could use a mechanics stethoscope and put on the shaft log and see if u can pin point the noise. The other possibility could be the strut bearings could be bad after the log hit. U could uncouple the prop shaft from transmission and then run transmission up to 2000 rpm's to eliminate the engine and transmission. U would then know its after the transmission. Good Luck!
Agreed. ...on the probable issue and on the diagnostic approach.
- throwback2
- Vessel Info: 1987 Carver 28 Voyager,twin small blocks,1991 Shamrock,350 Chevy now.
and a few other water toys - Has thanked: 8 times
- Been thanked: 23 times
- crquisto
- crquisto
