1985 3607 Aft electrical problems
rvance
Vessel Info: 1985 3607 Aft Cabin
Re: 1985 3607 Aft electrical problems
Postby rvance » July 28th, 2017, 11:11 am
I believe the Onan is the original gen from 1985. It is a 6.5. Anyone know where the resister is located?
rvance
Postby rvance » July 28th, 2017, 12:01 pm
This has to be from crossing the hot and ground. The gen was working fine before i did that. Does anyone know what could of been effected by this?
Been thanked: 1112 times
Postby km1125 » July 28th, 2017, 1:33 pm
rvance wrote:Source of the post I believe the Onan is the original gen from 1985. It is a 6.5. Anyone know where the resister is located?
What resister?
When you say you "shorted a power and ground"... was that a 12vdc circuit or a A.C. circuit. If it was A.C., was the generator running at the time you shorted it?
rvance
Postby rvance » July 29th, 2017, 3:22 pm
It was a.c.. It was not running at that time.
rvance
Postby rvance » August 16th, 2017, 12:43 pm
Would a relay keep the gen from running? any ideas on where to find relays for this?
Postby g36 » August 17th, 2017, 6:40 am
yes a bad relay can keep the genset from running and do what your saying. i believe its the K1 or k2 relay assuming a onan mcck its been a while since i had mine. also checked fuses on genset? in the old genset they were just mounted in the box but newer maybe yours dont know, but they went to a circuit board. what model do you have? you didnt say what model onan that i noticed, the control box will have the relays in there. you will likely have 3 they are identical and do different jobs. also there is a safety circuit that shuts down the engine such as over temp, oil pressure pressure switch etc.
rvance
Postby rvance » August 23rd, 2017, 3:51 pm
Do you know where I could get these relays?
rvance
Postby rvance » August 23rd, 2017, 3:57 pm
My gen doesn't have a circuit board. I do have k1 k2 relays
rvance
Postby rvance » September 26th, 2017, 4:44 pm
I can jump the relay to the fuel and the generator will stay running but still wont make power. What would shut down the fuel?
Return to “Electrical”
Users browsing this forum: Google Adsense [Bot] and 62 guests
