Engine removal from 1991 38' Carver Aft Cabin
- bikeboybob
- Vessel Info: 1991 Carver 38 ft Aft Cabin
- Been thanked: 646 times
Re: Engine removal from 1991 38' Carver Aft Cabin
- Has thanked: 598 times
- Been thanked: 1281 times
- Has thanked: 469 times
- Been thanked: 1765 times
I take it you have 7.4L/454 gas engines? Or are they diesels? Why do you have to remove the engines, what's wrong with them?
- bikeboybob
How many hours on the engines?
Are these raw water or fresh water cooled (coolant) engines? What about the manifolds; raw water or fresh water cooled? How old are they?
- bikeboybob
- tonyiiiafl
- Has thanked: 601 times
- Been thanked: 193 times
mY 1994 cpmy HAD AN ENGINE REPLACED. they REMOVED THE ENGINE FROM THE BILGE, REMOVED THE MANIFOLDS AND HEADS AND CRANK AND TOOK OUT PRETTY MUCH THE BARE BLOCK. Sorry about the CAPS!- km1125
- Has thanked: 78 times
- Been thanked: 1093 times
What's wrong with that? I have two 1983 454's still running fine!
+1
Ya, no problem with my '89s either but I don't have a chocolate shake going on. If I did though, I'd still try to get more years out of them by checking to make sure the issue wasn't just an upper end problem before I went through the time and expense of complete replacements.
