Winterizing the cabin
- denpooch
- Has thanked: 85 times
- Been thanked: 87 times
I have winterized all of the mechanical and fresh water systems on my boat. I do however have some questions regarding the cabin.
Do you folks keep the cushions (ultra leather) in place or do you take them off of sofa, etc. and place them where they can 'air out'?
I would also like to know if you keep cabinet doors in both kitchen, head and bunk opened or closed.
How about bedding? Do you leave it on the boat during the winter and then dry clean in the spring?
Since my boat will 'wrapped', is it recommended to keep the ports closed or open for ventilation?
The one thing I do know about is keep a couple of 4 pound 'Damp Rid's' in there.
Sorry for the length of this, but I would certainly appreciate your experience and thoughts.
- Agriman
- Vessel Info: 1998 Carver 350 Mariner Twin 454 Crusaders
- Has thanked: 5 times
- Been thanked: 5 times
Re: Winterizing the cabin
We leave the ultra leather seats on a cocked position to allow air around them.
We leave cupboards closed and doors open including the refrigerator left ajar.
We take the bedding home for cleaning and then return and leave in the boat in a tote.
We open the front windows for extra venting before shrinking
We leave dishes, silverware and cooking utensils until spring and then rewash them.
We mix calcium chloride and kitty litter about 1/3 to 2/3 mixture in plastic containers (3 of them) from the dollar store to handle any humidity issues.
- Has thanked: 469 times
- Been thanked: 1765 times
When they wrap your boat, ensure they install plenty of vents.
- Has thanked: 78 times
- Been thanked: 1093 times
- Has thanked: 598 times
- Been thanked: 1281 times
- Been thanked: 1180 times
- Been thanked: 601 times
We don't use the humidity buckets. I believe they draw everything they can in the first two weeks or so, then let it wick back out with the dry winter air.
tomschauer wrote:Source of the post.... We don't use the humidity buckets. I believe they draw everything they can in the first two weeks or so, then let it wick back out with the dry winter air.
Agreed. I don't understand the logic of using them in the winter. Unless you visit the boat every month and replace them you're actually leaving a source of moisture on board. It's dry in the winter so I don't see the point. I guess it's good marketing and I understand the use in the summer, but in the winter, just ventilate.
Viper wrote:Source of the posttomschauer wrote:Source of the post.... We don't use the humidity buckets. I believe they draw everything they can in the first two weeks or so, then let it wick back out with the dry winter air.
All I know is they only start to work if the humidity levels get above 60%. In spring the containers are full which means the liquid removed was taken from the air and is not absorbed in the boat.
- Has thanked: 64 times
- Been thanked: 481 times
Shrink wrapping it does not make the boat vapor pressure proof.
