Small boat big big project!
Re: Small boat big big project!
The purpose of the alignment tool is to get the engine's crankshaft/coupler and gimbal bearing in line. Grease is applied to the end of the alignment tool that gets inserted through the gimbal bearing into the coupler. When the tool is pulled out, the pattern of grease left on the tool indicates which way the engine must be moved to achieve alignment. This must not be forced. In a proper alignment, the tool will slide in and out of the coupler easily.
- edcourter
- Vessel Info: 86 2667
Are you taking the Oswego route? I think it is also the 200 year celebration of the Erie. I'm trying to head East out of Fairport (Rochester) 3rd wk of June after about 5 days of preparation and test launch from Macedonia Landing.
- hardchines
- Vessel Info: 1980 Carver
2667
Santa Cruz - Has thanked: 8 times
- Been thanked: 29 times
The Erie seasonal lock pass is 50 dollars under 26 feet, you are 25' 10 "
,- hardchines
2667
- Been thanked: 1111 times
Before you got to the part about the generator, I was thinking you were going to bolt up a high voltage A.C. alternator right up to the diesel and use that for A.C. power. You could also bolt up a high-output DC alternator and run a larger inverter for everything but the air conditioning.
- hardchines
2667
- Dohcdelsol93
- Vessel Info: Carver santa Cruz 25 or 26 ft...someone tell me
Sanjuan 26
Y flyer 18 - Location: Upstate sc
- Been thanked: 2 times
how did you run the switches for the shifter (cut off) or does the diesel idle lope slow enough to shift without grinding/damaging the alpha unit between gears.
I would also like to know more about that exhaust
I'm restoring a 1978 carver and i'm a bit of a diesel nut (done several land cruiser diesel conversions) and would love to have another MPG friendly boat for cruising the keys and fishing the protected waters along the coast of SC.
How does it do in currents? I'm a lake sailor and currents are something I've never had to deal with so I have no experience with them.
I'd love to find a way to calculate how to maybe cruise a little bit more, maybe 10-15 mph, maybe safer when fighting a current? Play with prop size? I would think that the alpha 1 could handle diesels in the sub 125 hp range. The higher reving, ligter, and shorter stroke the better. The torque vibrations (rather than pure torque output) are what I would think would kill an outdrive quicker than anything else. The torque pulse can do weird things to bearings and soft metal parts.
- hardchines
2667
cruise speed at 10 mph is out of the question, too slow to plane just plowing water!! 13-and up with the boat lite would be more like it, 1800 rpm gives me 6.1 mph little wake, 2600 rpm gives me 8 mph and a huge wake!
boats do not see currents, they do not know the water is moving past them
- edcourter
- hardchines
2667
