Adding Batteries
- Has thanked: 598 times
- Been thanked: 1281 times
Re: Adding Batteries
- ataylor233
- Has thanked: 83 times
- Been thanked: 7 times
- MakinTime
- Vessel Info: Carver 3607 MakinTIme
Glastron MX175 MakinTimeToo - Has thanked: 52 times
- Been thanked: 31 times
- Has thanked: 469 times
- Been thanked: 1765 times
- MakinTime
MakinTime wrote:Source of the post I was told by xantrex not to use a anl type fuse for the install for whatever reason I don’t know. I used a blue sea fuse holder and fuse. Located very close to my batteries. Reading on them now looks like they are insulated and coast guard compliant. But says nothing about being ignition protected. I may have to research this a bit more..
I have a question as I have been following this with interest ( might be something I do )...If the inverter maker specs a quick blowing fuse for their marine install to protect their stuff, then is it possible at all, that with the appropriate fuse holder then all is protected for gas engine because of the holder....dont know just asking.
- ataylor233
so take the wires from the shore power to the input of the inverter and from the inverter to where the shore power plugs in
bud37 wrote:Source of the post....is it possible at all, that with the appropriate fuse holder then all is protected for gas engine because of the holder.....
I've never seen an ignition protected class T holder but you never know. The typical holder is open-ended. I suppose you can try and install it in a sealed box but you'd have to ensure any wiring inlet/outlet completely seals around the wiring/cable with no chance of vapor ingress. You could encase the fuse and holder in a sealed box and install thru-box studs so the posts are on the outside of the box but why go through all that trouble when you can simply install an ignition protected fuse. Considering the fuse shouldn't be more than 7" away from the source, it doesn't give you much room to mess with.
They talk about ignition protection requirements in gasoline engine rooms but really when you think about how close to the battery you should be installing the fuse, it's also a concern in a diesel application. It's not just the fossil fuel you have to worry about, if your battery is gassing off and a non-ignition protected devise fails in proximity to it, you'll have a battery explode whether it's a gasoline engine bay or not.
- Has thanked: 78 times
- Been thanked: 1093 times
The possibility of a wire being compromised is much , much lower than something at the end of the circuit overdrawing current and causing the wire to overheat if it's not fused appropriately.
