New GPS this Spring
- denpooch
- Has thanked: 85 times
- Been thanked: 89 times
New GPS this Spring
I am planning to upgrade the GPS on my 36 this Spring and would like to get feedback on the unit's screen size most appropriate for this vessel. As you know the screen sizes range from 5" and go on up.
My thinking is leading me to a 9" display. Does it make sense to look at 10 or 12"... or smaller for that matter?
Although there is a cost differential as I move up in size, I figure that I will be upgrading just one time and want to 'get it right'.
What display size do you folks use? Which manufacturers do you like?
I know one person that has their unit mounted on an 'arm' to move around. Does anyone employ that kind of configuration?
I will be likely be looking at models with a touch screen.
All thoughts are much appreciated.
- Been thanked: 654 times
Re: New GPS this Spring
- denpooch
Regarding the arm/pod... is it secured using fasteners (drilled holes) or some kind of suction or Velcro fixation?
Also, since you mount as such does the unit function as a 'stand alone' or is it in fact interfaced to other systems (auto pilot, depth transducer, etc.)
I appreciate your input.
- Has thanked: 602 times
.......when I go from my old ray marine stuff, I will return to a Garmin something...likeky the 9 or 10" touch screen versions ....had one before and loved it, almost intuitive and you can interface all your engine data etc, etc on them, if you have a data bus etc installed, skies the limit I guess.......
- denpooch
They also feature a card that will provide a recommended route for your trip. I think that this feature will be helpful in unfamiliar waters. I dont know if other vendors offer that same routing software.
- RGrew176
- Has thanked: 72 times
- Been thanked: 470 times
My Garmin unit.
- denpooch
Thanks for the feedback.
- smoky mt gypsy
- Vessel Info: carver 3200 1995
