Adding Batteries
Re: Adding Batteries
We should keep in mind that there is a lot of current involved when we're talking about inverters. Should something go wrong, it will have catastrophic consequences even with the smallest oversight, cheaping out using low quality hardware, or improper installation practices. I've seen the results of some failures due to these, it's not pretty. And some installs were done by so called inverter installers/system design engineers. The problem is that they're typically versed in residential installations, and are unfamiliar with marine practices so they use non marine hardware and installation techniques. The install might look good to the average person but a good surveyor will quickly tear it to shreds and condemn its use. A failure in a poorly installed system with improper hardware may not be covered by the insurer if it's discovered proper installation practices weren't adhered to, it's their way out of honoring a claim.
- Has thanked: 602 times
- MakinTime
- Vessel Info: Carver 3607 MakinTIme
Glastron MX175 MakinTimeToo - Has thanked: 52 times
- Been thanked: 31 times
I usually make up a label relative to the installation such as:
CAUTION - POTENTIAL ELECTRICAL SAFETY HAZARD
This vessel is equipped with an automatic switching inverter. It will supply AC when shore power or the generator is off.
Disconnect AC shore power AND turn off DC power to Inverter before servicing electrical panel.
The inverter’s DC battery shut off switch is located in the aft cabin, starboard side lower cupboard, beside the stairs.
ALWAYS test and ensure no power is present before working on the electrical system
- ataylor233
- Has thanked: 83 times
- Been thanked: 7 times
ataylor233 wrote:Source of the post how much ventilation should the inverter have? i would love to mount it in the aft cabin, in the closet along the engine room wall. It's right under the salon stairs maybe a small computer fan to vent the closet.This will allow me to run the wires through the back wall.
Where are you thinking to run the vent to, sounds like a good idea regardless, maybe with a switch that would turn the fan on when a certain temp is reached........could you possibly vent it out the side of the hull from that spot if that would be needed ??......
- ataylor233
[/quote]im thinking on both sides of the stairs and one at the bottom of the door for that closet as a intake . wired to a temp switch should be easy.
