Hot Water Heater Leak
Ssmullugan
Vessel Info: 2000 Carver 326 aft cabin
Has thanked: 3 times
Postby Ssmullugan » November 12th, 2017, 1:00 pm
We have a 326 aft cabin (new to us) and having a plumbing issue. Heard a “pop” last night, then water pump is runni g continuously. No water pressure. Shut everything down. Found water around hot water heater and can hear a drip if we run the water pump for a minute. Carpeton floor in cabin is wet-below hot water heater. Sumps are all good.
Thoughts?
Has thanked: 598 times
Been thanked: 1281 times
Re: Hot Water Heater Leak
Postby bud37 » November 12th, 2017, 1:18 pm
Welcome to the forum.......possible pressure relief valve on tank let go and maybe is now stuck open, hopefully you shut off the power to the heater quickly to save the element.If so easy fix.......good luck......
Ssmullugan
Postby Ssmullugan » November 12th, 2017, 3:16 pm
Thanks for the reply.... think we actually blew a hole in the water heater.... water seeping from bottom. Going to order a new one and install. Pretty easy access. We will keep posted in results
Ssmullugan
Postby Ssmullugan » November 18th, 2017, 4:03 pm
Good news- Got the old hot water heater out, replacement in.working like a charm!
Been thanked: 246 times
Postby mjk1040 » November 19th, 2017, 5:11 am
Great! :beergood: Welcome Aboard!
