Rudder sending unit adjustment
- Helmsman
- Has thanked: 73 times
- Been thanked: 42 times
Re: Rudder sending unit adjustment
Your unit doesn't use a reference voltage, and because voltages will vary and typical usage is with the engines running, you should also confirm that the reading stays the same while the engines are operating. After you've made your adjustment, run the engines to confirm nothing changes. It may change slightly but a big change indicates an electrical issue or low battery and your alternator is now outputting at a high level, so ensure your batteries are fully charged before making the adjustment.
- Lyndon670
- Has thanked: 124 times
- Been thanked: 140 times
2000 Carver 506
FOXY JOE
Volvo 7.4TAMD
Queens Cove Marina
Georgian Bay, Ontario
- denpooch
- Has thanked: 85 times
- Been thanked: 89 times
If you have an auto pilot on your boat there is something to keep in mind.
When making the adjustment on my rudder sending units, we inadvertently dislodged the autopilot sensor which completely 'threw off' the auto pilot function. I would be following a heading and as soon as I engaged the autopilot to maintain the course, she would start going in circles. As you can imagine, it was very disconcerting.
After weeks of phone calls, stressful thoughts of having to replace a faulty computer, etc., we figured out the culprit.
We reattached the piece and recalibrated according to instructions and 'carried on' with life.
Certainly not a big deal but something that should be kept on mind.
denpooch wrote:Source of the post I had made the same adjustments this past summer.
You must have a different setup compared to mine as the autopilot is on the port side which has it's own dedicated unit with the markings RayMarine on it. In other words I have 2 rudder indicator setups, one for the Auto pilot and one for the rudder indicator gauge.
- denpooch
- Helmsman
The AP sender is on the Port side of the boat so it won’t factor in. i will need to look for the locknuts. I can see one in a couple of the pictures I took.
Thanks for the help! Will report back after I climb in there. if I can get back out!
- Has thanked: 603 times
- daveS
- Vessel Info: ☀️Sanity Sol☀️
1999 350 Mariner - Location: Penetanguishene, Ontario
- Has thanked: 24 times
- Been thanked: 8 times
Users browsing this forum: Rocketman and 42 guests
