Water tank gauge
- Helmsman
- Has thanked: 73 times
- Been thanked: 42 times
Water tank gauge
I have a Xintex Water Tank Display Round 2in Gauge for 1 Fresh Water Tank that is not working. The other holding tank display works. I haven’t pulled the lid cover off of the electrical panel to see if it is receiving power but thought I would ask here first I forgot any of you have replaced or repaired one. While I would prefer not to buy one, if I need to I will. I assume there is a sending unit in the tank I may need to locate and test somehow. Any thoughts out could share, I would certainly appreciate it.
- mjk1040
- Been thanked: 248 times
Re: Water tank gauge
Here is a link with some manuals that might be helpful:
http://www.fireboy-xintex.com/pneumatic-liquid-level-monitor-systems/
- Helmsman
is there a way to check the current from the sending unit to make sure it is the culprit? Open to anyone to answer of course.
On the waste monitor, you have to push on it and it lights up and tells you how full it is. I assumed the fresh water gauge should do the same. Since the light won’t come on it may indicate a problem with the gauge.
http://www.fireboy-xintex.com/wp-content/uploads/2014/07/PneumaticLLMinstructions.pdf
- Helmsman
Viper wrote:Source of the post If it's the pneumatic type sender, there is nothing to corrode if I remember correctly. This might help, there is a troubleshooting section:
Thanks for the link. The condition as it exists is that the lights on the display do not illuminate when you push to illuminate it. I will take the panel cover off and see if it is connected. Perhaps the previous owner disconnected it. If it isn’t the gauge or power to it, the only other thing it could probably be is the sending unit. After I check the gauge I will move to the sending unit.
Thanks!
Nate
- jwcyacht
- Vessel Info: 2002 carver 396
- Contact:
mjk1040 wrote:Source of the post Most likely sending unit is corroded. If 12 volt breaker is on for this unit, it should be illuminated.
I cannot locate the sender unit on the tank for my 2002 carver 396 and nothing in the docs tell me anything about it. Any help?
- Helmsman
Yes that was an expensive option on some models. It's amazing what nano technology can do
Users browsing this forum: No registered users and 115 guests
