Fuel problems
Has thanked: 64 times
Been thanked: 481 times
Re: Fuel problems
Postby waybomb » June 12th, 2013, 6:32 pm
Good for you! Enjoy for a change!
jwaggoner
Vessel Info: 2001 Carver 404 motor yacht
Re: Fuel problems
Postby jwaggoner » January 18th, 2014, 7:32 pm
I have 454 Horizon engines and have replaced the fuel pumps on both engines each year now for the past 3 years. The boat is not used much but I do start the engines frequently.
I have been told that there are some mechanics putting boost or lift pumps up stream of the fuel pump. Is this acceptable? Also I have not checked the syphon valves.
Users browsing this forum: Google [Bot] and 23 guests
