Exhaust risers
- jcoll
- Has thanked: 18 times
- Been thanked: 18 times
Exhaust risers
- hausherrs
- Vessel Info: 1996 Carver 400
- Has thanked: 5 times
- Been thanked: 10 times
Re: Exhaust risers
I was asking the same question when I decided on OEM. You cant go wrong. Spend a little more and get the good stuff.
Risers:
https://www.marinepartssource.com/newde ... no=R029015
Manifolds:
https://www.marinepartssource.com/newde ... o=R028021A
- MakinTime
- Vessel Info: Carver 3607 MakinTIme
Glastron MX175 MakinTimeToo - Has thanked: 52 times
- Been thanked: 31 times
Re: Exhaust risers
- jcoll
Re: Exhaust risers
Both sides of it have valid points. Personal preference is the deciding factor. It does look like Marine Parts Source has the best pricing currently for OEM.Since my engines are fresh water cooled I was not intending on replacing the manifolds, just the risers (elbows). I don't see a benefit in replacing the manifolds. My initial inspection 4 years ago showed no serious sign of deterioration. My previous boats were all raw water cooled and they got manifolds without question. Are your system fresh or raw water systems and if fresh, what would the reasoning be to replace the manifolds?
Re: Exhaust risers
- jcoll
Re: Exhaust risers
What was the issue you had with the one aftermarket manifold?
Re: Exhaust risers
- denpooch
- Has thanked: 85 times
- Been thanked: 89 times
Re: Exhaust risers
The risers are $158.00 per each and the metal gasket is about $55.00 each. These are Crusader OEM.
Lots of luck.
- jcoll
Re: Exhaust risers
- mjk1040
- Been thanked: 248 times
Re: Exhaust risers
