Exhaust risers
- jcoll
- Has thanked: 18 times
- Been thanked: 18 times
Re: Exhaust risers
- jcoll
Re: Exhaust risers
- Has thanked: 603 times
Re: Exhaust risers
- jcoll
Re: Exhaust risers
- mjk1040
- Been thanked: 248 times
Re: Exhaust risers
- jcoll
Re: Exhaust risers
Re: Exhaust risers
http://www.anthonykeatsmarine.com/
- mjk1040
Re: Exhaust risers
- jcoll
Re: Exhaust risers
mjk1040 wrote:Source of the post Well there seems to be room for and additional 1.5" riser height. But if your engines after mounting and alignment are higher than mine are presently sitting, its going to be tight. If you go with the higher riser you may end up with the riser now inside the floor grid system and if the taller riser happens to be a little bit wider, you may have your new riser rubbing on the floor grid system.
Thanks, that's good info. & I appreciate your effort. I contacted Viper's recommendation and they indicated they can get OEM Crusader parts. I'll follow up after everything's been completed.
Re: Exhaust risers
