Engines won't start!!! Batteries?
- RickieT
- Vessel Info: Carver 350 Mariner 1997
- Has thanked: 18 times
- Been thanked: 3 times
- Contact:
I believe I'm having an issue with where my batteries are drawing their power. Consequently my engines won't start...they just make a clicking sounds when turning over. I have 3 batteries...one is in the bilge where my port engine is. Tested and it has plenty of power. There are 2 other batteries in a row directly below the middle hatch between the two engines. One
I believe is sucking the power from the other one and engines aren't starting. One battery is brand new and the other was already in the boat when I purchased it last year. I am looking for any help as to why the engines aren't turning over. I'm guessing one of the batteries isn't holding a charge? I'm also curious as to what I'm supposed to set the knob in the salon panel for the batteries? Choices are Both, 1, 2, off. My next step is to perhaps take the 3 batteries to be tested to see if they are ok?
Rick
Re: Engines won't start!!! Batteries?
The other two are your main batteries connected to the battery switch.
With the switch in the off position you should have no power to anything other than bilge pumps, shower sumps and CO detectors and most likely stereo memory.
With it in the 1 position what ever battery connected to that side of the switch will feed all loads. When switched to 2 that battery will feed all loads.
When in the both position both batteries are paralelled and feed all loads.
you didnt say whether or not you are connected to shore power and the charger is on?
Many things on your boat will draw power from the batteries constantly. If the charger is not on you should shut off all 12v breakers that are not required or you will have dead batteries on a regular basis.
- RickieT
- Contact:
tomschauer wrote:Source of the post The battery in front of the port engine is most likely dedicated to the generator.
I am connected to shore power...and where would I see if the charger is on???
- mjk1040
- Been thanked: 248 times
- mjk1040
- RickieT
- Contact:
- buster53
- Has thanked: 10 times
- Been thanked: 285 times
What position is your 1-2-Both-Off battery selector switch in?
Try starting your engines in all three positions...1-2-Both and let us know what happens.
If you are sure the battery charger is on and has been for a while. The engines should start easily in the "Both" position. Since one battery is new and the other is not, there's a good chance that in either the "1 or 2" position, one battery will start the engines fine, but the other battery may struggle if it starts the engine at all. The one that struggles will surely be the older one and should be replaced. When it comes to batteries, it's best to replace both at the same time.
When you are out cruising, always have the selector in "Both". If you stop, say to anchor out for the afternoon, and you don't want to run your generator, always put your selector in either the 1 or 2 position, so both batteries won't run down while at anchor and you still have one strong one to start your engines. You should always have big enough/strong enough batteries that only one is needed to start engines. If you need to use both, something is wrong.
Not giving you a hard time but you sound like a newbie with regards to larger boats. I suggest you enlist the help of one of your more seasoned boating buddies to go over some of the systems on board that you might not be too familiar with.
- RickieT
- Contact:
Thanks,
Rick
- Has thanked: 602 times
- Been thanked: 1310 times
So really the only power on the boat is the 120volt circuit feed to the fridge. Lots of folk leave the air on etc but we are there enough so it is not a problem, also the bilge pumps are hard wired in to the batteries,also the CO monitors but they can be shut off though on our year.Took me a while with some issues much like yours, so I know that this works for us now.
Now I am not saying you should do it this way, just an example, everyone has different needs and I full agree that you should get a little local help for a bit as this is quite a learning curve and takes years sometimes......good luck man.......
