Looking at a 41 CPMY
jspin101
Vessel Info: 2005 Carver 41 CMY w/ 2006 Volvo D6 370I-B's
Has thanked: 8 times
Been thanked: 2 times
Re: Looking at a 41 CPMY
Postby jspin101 » February 25th, 2018, 3:37 pm
We had the survey on the hard Friday.
Nothing major was found :-D
Next up, the Sea Trial. :captain:
Looking for the end of March.
Although I was corrected. It is now called a Water Trial.
Something about a Sea Trial in a fresh water river. Things went bad afterwards and that brought about a law suit.....Always something....
jspin101
Postby jspin101 » February 25th, 2018, 3:51 pm
MidnightSun,
During the survey the surveyor was looking thru the engine area and we noticed, on the port side aft of the engines there was a seacock that was way out of reach, the hose was heading forward towards the genny . Is there access to that area? The Trannys are in there also. How do you get to them?
We could see it through the access doors on the steps coming from the Master stateroom. It almost looks like the stairs may pull out although it's only my 3rd time on the boat and didn't get a chance to check it out.
Thanks,
Has thanked: 598 times
Been thanked: 1281 times
Postby bud37 » February 25th, 2018, 4:33 pm
jspin101 wrote:Source of the post We had the survey on the hard Friday.
One down and one to go.......water trial heh,interesting semantics....again more good luck man........ :beergood:
Been thanked: 601 times
Postby tomschauer » February 25th, 2018, 4:40 pm
Not sure what seacock you are referring two, but the port side should be fairly accessible. You need to climb in the hole.
The starboard side is the difficult area to access.
Yes, the stairs do lift out. I believe four screws if you look closely.
jspin101
Postby jspin101 » February 26th, 2018, 6:14 pm
Tomschauer, thats good news if the steps come out because there is no way I'm fitting thru the hatch on the stairs. it's a foot wide if that. The surveyor was baffled how far out of reach the seacock was. It was Port side on the 41 CMY.
Has thanked: 64 times
Been thanked: 481 times
Postby waybomb » February 26th, 2018, 6:37 pm
jspin101 wrote:Source of the post there is no way I'm fitting thru the hatch on the stairs. it's a foot wide if that. The surveyor was baffled how far out of reach the seacock was.
This is what wives are for............
Been thanked: 468 times
Postby RGrew176 » February 26th, 2018, 10:40 pm
It's really to bad that those who design boats are not necessarily the ones who work on or in them. It can be challenging sometimes.
2022 Stingray 182 SC
Been thanked: 1180 times
Postby Midnightsun » February 27th, 2018, 6:31 am
Stairs definitely lift out, no screws. In fact you almost need to lift them out if you want do any serious work on the engines.
Has thanked: 469 times
Been thanked: 1765 times
Postby Viper » February 27th, 2018, 6:36 am
I don't remember any screws. I do seem to recall that they need to lift straight up.
jspin101
Postby jspin101 » February 28th, 2018, 7:36 am
Thats real good news with the steps. I asked the wife and she replied :censored: So I took that as a no. haha There was a seacock that was really loose, could reach it but couldn't see it and that other seacock that couldn't be reached. Also the mechanic would need to get to the trans. Thanks for all the info.
