Spark Plug Wires ???
- amanphoto
- Has thanked: 3 times
- Been thanked: 12 times
The issue...
I have a 1999 Carver Mariner 350 with Mercruser Gas engines (300 hours in fresh water). Last summer the engines would not rev very high. It started great and idled great. The problem turned out to be old and crusty spark plugs and distributor. After gaping 16 new plugs and fighting in the tight spaces around the engine and fuel tank, I was able to replace them. The boat runs great now. My car mechanic said not to replace the wires. Reason - the new stuff is crap and don't contain as much copper as the old wires and are lesser grade. My boat mechanic said to replace the wires just because they are old. They are not arcing. They don't show any discoloration and are still very pliable. There is not corrosion on the wire caps.
What is your opinion?
- Has thanked: 597 times
- Been thanked: 1275 times
Re: Spark Plug Wires ???
- Has thanked: 467 times
- Been thanked: 1759 times
- Been thanked: 601 times
- feeez
- Has thanked: 52 times
- Been thanked: 66 times
bud37 wrote:Source of the post I would inspect them close for nicks and pinches and check the ohms, if ok leave em.......Heh a question related to the plugs, this I have to do on the same boat....how long did it take and any special tools / mods...thanks......
Keep a pack of bandaids handy for your knuckles......
Cheers
Fraser
- Has thanked: 58 times
- Been thanked: 470 times
If you don't see anything, probably a-ok.
If you have a bent for pain, start em up and start grabbing wires. You'll find any current leakages pretty quickly.
edit - if they are this far gone, you have a big safety problem. I change my wires every 5 years of so, and buy OEM sets, not cheap knock-offs.
PV gets really good wires, probably overkill. Don't need those for the Carver.
- mjk1040
- Been thanked: 245 times
Seen new spark plugs that are bad!
- dcrahn
- Vessel Info: 1984 Carver 2687 Monterey
- Been thanked: 4 times
- mjk1040
