Port/Starboard Handrails
StDuckie
Vessel Info: 1991 3607 Aft Cabin Cummins 6BTA
Has thanked: 29 times
Postby StDuckie » March 20th, 2018, 6:47 pm
Are the screws that hold the handrails wood or machine w/a nut?
Re: Port/Starboard Handrails
Postby Viper » March 20th, 2018, 7:03 pm
Welcome aboard. They should be thru-bolted to the deck either with nuts or through threaded holes in a backer plate. Some applications have the backer plates glassed into the fiberglass.
Postby km1125 » March 20th, 2018, 7:56 pm
Not sure how much they changed from my '83 to your '91, but they are are machine screws on mine. It's a bit difficult to get to some of the nuts on the underside....you need to remove panels in a lot of places and have long reaching arms.
StDuckie
Postby StDuckie » March 21st, 2018, 12:39 pm
Hi all. Appreciate the insight. Looks like I'll be removing panels....big mess...thanks again. :banghead:
Postby bud37 » March 21st, 2018, 12:56 pm
You may just have the machine screws going into the threaded backers......see if you can find a spot to look behind first.
Been thanked: 491 times
Postby waybomb » March 21st, 2018, 5:52 pm
If they just spin, probably loose nuts.
On our project, we just about removed every bit of interior and took advantage of that. Every screw was loose. Pulled them all, rebedded the stanchions, and installed new screws and nuts with much larger washers
Postby Viper » March 21st, 2018, 6:47 pm
When you tackle this, following up with locations, what you had to remove to get there and some pics would really help others planning on doing the same thing to their 3607. We loves pics ;-)
StDuckie
Postby StDuckie » March 22nd, 2018, 3:40 am
Thank you for taking the time to give sage advice. Very helpful. When I tackle project "loose screws" will definitely take pics. Ciao :captain2:
Postby Viper » March 22nd, 2018, 6:52 am
What are you planning on using to seal the holes and fasteners with?
StDuckie
Postby StDuckie » March 23rd, 2018, 7:30 am
Was not planning on “sealing” any holes. From what I’ve learned the screws are machine, hence there is a “nut.” So, my goal is to remove inside panels sufficient to expose the nuts and tighten using thread lock. Inspection reveals that R&R the panels is going a significant chore, i.e. 1-2 days. :beergood:
Users browsing this forum: No registered users and 43 guests
