Port Engine Overheating
- RickieT
- Vessel Info: Carver 350 Mariner 1997
- Has thanked: 18 times
- Been thanked: 3 times
- Contact:
Re: Port Engine Overheating
- RickieT
- Contact:
- mjk1040
- Been thanked: 248 times
- RickieT
- Contact:
Thank everyone for all the input!
Rick
- mjk1040
- dtlag
- Vessel Info: 1999 Carver 406 Aft Cabin Motor Yacht
- Has thanked: 2 times
Did this fix your problem? I'm having the same problem on my Carver 406. The coolant disappears, but is nowhere to be found.
Thanks!!
- 390Express
- Captain
- Has thanked: 141 times
- Been thanked: 15 times
dtlag wrote:Source of the post Rickie,
Thanks!!
I had the same issue, mine puked out of the radiator cap, I believe, and was evacuated out of the bilge by the pump.
The issue that I'm having is, my over fill reservoir will be near empty, I'll add a small amount, then it will puke out everywhere. It's done it three times now. I think what's happening with mine is, I have air in the system, and its burping its way out, but making a mess in the process. I don't really see an air bleed anywhere, so I guess I just have to deal with it for the time being.
- Has thanked: 602 times
- Been thanked: 1310 times
There are many other reasons for coolant dissappearing, coolers, exhaust, line leaks, bad pressure cap, etc......but consistent over pressure in there is fairly telling.
Dtlag, welcome to the forum.
Best of luck!
- 390Express
- Captain
tomschauer wrote:Source of the post If your reservoir runs low and then over flows it may be riser gaskets or the heat exchanger. When the engine is cold you may have higher pressure on the raw water side letting water into the system. When it gets hot you would have your fresh water (anti freeze) bleed into the raw water system and out the exhaust. You may want to check and make sure you have sufficient freeze protection for the winter until you find and solve the problem.
Best of luck!
Thanks Tom. For the winter I always winterize the freshwater side of the motors, and after winterizing them I disconnect both ends of the heat exchanger and pull all of the block drains and riser/manifold plugs completely out. There's no sense leaving the RV antifreeze in the system where it's not needed. I'll see what I can do about pressure testing the manifolds and risers this spring. I think I just have air in the system, but I can't find any sort of bleed screw or way to get the air out of the closed loop, other than let it keep burping and refilling the reservoir.
