Kohler generator for dummies, questions
sep4086
Vessel Info: 1990 3867 SANTEGO
2003 PRO LINE 26 WALK
Has thanked: 2 times
Re: Kohler generator for dummies, questions
Postby sep4086 » January 1st, 2018, 11:53 am
To me it sounds like the water pump impeller might be weak and needs to be replaced. If you have good water flow out the exhaust pipe then maybe the thermostat or the high temperature sensor might be bad.
Keith S
Vessel Info: 2005 38 Super Sport
Been thanked: 21 times
Postby Keith S » January 3rd, 2018, 2:41 pm
I would suggest that when someone is looking for advice on a generator to post the exact model you have. I work on these for a living and each model has it's own quirks and issues. What may be great advice for one model may have nothing to do with a different model. Of course generic things like replace the impeller regularly apply to all.
Has thanked: 469 times
Been thanked: 1765 times
Postby Viper » January 3rd, 2018, 10:26 pm
++1
Always best to provide as much information about the hardware as possible.
Helmsman
Has thanked: 73 times
Been thanked: 42 times
Postby Helmsman » March 16th, 2018, 10:19 pm
glazingguru wrote:Source of the post Well, I figured it out and it wasnt that hard. HOWEVER, the damn thing still ran for a while and then shut itself off. I couldnt figure it out so I asked a mechanic to look at it. Come to find out, the wet muffler was shot and leaking into the bilge. The guy said it was even possible it could leak while not being run??? Anyway, I am replacing it and I hope that cures the problem with it shitting itself off because I suspect it was overheating.
I had the problem with the Benny shutting off last year on a Kohler 7.3E. Turned out, all it was, was that the oil level was low. Evidently, they don’t like being run with the oil low just a little.
Been thanked: 246 times
Postby mjk1040 » March 17th, 2018, 3:35 pm
Glazerguru, in ur original post u stated u shut the shore power off at the panel. The Panel mains have to be on in order to get electric from the generator. U should have a relay in the system that automatically switches from shore power supply to genny power supply. Or you can unplug the shore power to be sure. I just serviced our 1998 kohler genny and by the looks of things the impleller may have been changed once in 20 years. It was in bad shape. Fuel filter was original and I was unable to remove the anode pencil, all I got was the threaded brass end. That being said I try and run the genny every time we can with a load on it. U got to use it or u will lose it.
The Dash
Vessel Info: 1987 Carver 42Aft Cabin
Has thanked: 3 times
Postby The Dash » April 19th, 2018, 11:39 am
Keith S, I have a problem with the original generator of my 1987 42 Aft Carver. The model is Kohler 7.5R27, Spec 106276A. Aside from its vintage making it hard to find replacement parts, the generator starts but only keeps running if I exercise the fuel pump priming lever. I replaced the fuel pump with aTacit electric cube style pump, now it won't start at all.
Any suggestions?
Been thanked: 601 times
Postby tomschauer » April 19th, 2018, 7:33 pm
The fuel is polarity sensitive. If it runs backwards it doesn't pump any fuel. Try switching the polarity.
Postby tomschauer » April 19th, 2018, 7:34 pm
I meant the fuel pump, not the fuel it self. :banghead:
Postby mjk1040 » April 19th, 2018, 7:38 pm
I thought you were being a Smart A** Tom!
Postby tomschauer » April 19th, 2018, 7:41 pm
Not this time Mike!
Return to “Electrical”
