Vacuflush Lake Water Draw Advice
Re: Vacuflush Lake Water Draw Advice
- Has thanked: 602 times
Keep in mind the waters I boat in are really pristine and I would say drinkable in a bind. Would not recommend this modification in bad waters or salt water just like I would not activate it if I wander into bad areas and would refrain from using it in Marinas or other doubtful areas. This will mostly be used to save potable water when taking showers at times when we are away for several days. The main goal here is to not need to return to port because we are low on water and cannot flush the head. Bottom line this will be used infrequently but in place if needed.
Maybe some day.....
