New Battery Bank, now how to charge them!
Re: New Battery Bank, now how to charge them!
Postby Viper » May 5th, 2018, 8:50 am
paboater76 wrote:Source of the post..... I'm running 6awg for my battery leads, manual says this chassis ground can be 1 size smaller at 4awg....
Other way around; 4 awg would be one size larger. You want 8 awg.
paboater76 wrote:Source of the post ......I also got the remote panel for the pronautic, but I'm not sure I like it, I want a monitor that I can use to check and monitor my batteries while on anchor without the gen running. I think the promariner needs AC power for the remote to work, is that correct? this is why I'm leaning on returning it and going with a Victron BMV-712 Smart Battery Monitor.....
The ProNautic remote panel is for monitoring the charger function only and will only work while you have AC power, it is not for monitoring batteries conditions such as remaining capacity and other features, etc. For that you'd need something like the Victron battery monitor. They each have their specific function.
paboater76 wrote:Source of the post .....What type of 60amp fuse should I use?....
Most chargers use ATO fuses internally to protect their output circuits. If you're going that route, get the water proof ATO holder such as this:
http://www.marinco.com/en/607019
You can also use these from Blue Sea, they're pricier but a very good system: https://www.bluesea.com/products/5191/MRBF_Terminal_Fuse_Block_-_30_to_300A
paboater76
Vessel Info: 84 3207 Aft Cabin
Has thanked: 14 times
Been thanked: 5 times
Postby paboater76 » May 5th, 2018, 1:55 pm
haha yeah 8awg not 4 for the chassis ground. Brain fart. I'll have questions and pictures on where to connect the chassis ground later.
Yeah wife onboard. but i'm the one who cant take the humid nights and sleep, but we try not to sleep while on gen power. I do have several Co2 detectors but it still worries me. If it is that nasty out, I'm headed for the dock lol
Would this fuse holder be ok?
http://www.bestboatwire.com/maxi-fuse-i ... -up-to-60a
Yeah, I ordered the Vic with bluetooth, I might keep the Pronautic remote too it was only 75 bucks as it is designed to interface
Thank you all very much!
Postby Viper » May 5th, 2018, 4:33 pm
That holder will work fine. The one I posted is a better unit as it's sealed from the elements and if you're worried about ignition protection, it's a better option too.
paboater76
Postby paboater76 » May 5th, 2018, 5:45 pm
Thanks Viper, Only reason I posted the one I did, is that I cannot find the style you linked to in a 6awg lead? I would like to go with the terminal fuse blocks but I have clearance issue. Does Marico make a 6awg one? Or can you like to another brand.
Postby Viper » May 5th, 2018, 7:45 pm
I think you're going to find it a challenge to get an in-line holder for 60 amps. Actually, check but I think with that amperage you may need to move up to a Maxi fuse rather than ATO, and even then you may not be able to find an in-line with that size wire. There are kinds that will mount on a surface with contacts for you to hook up your wires to. I wouldn't stress too much about the sealed holder. Would be nice but if you can't find it then I wouldn't worry about it.
paboater76
Postby paboater76 » May 13th, 2018, 9:24 am
Thanks everyone who replied! I have finished my battery/charger project. I would love to post some pics, if someone could tell me what free 3rd party hosting I could use? I have google drive and google photos if I can use those to host some pics.
Here are more total costs and material used. TOTAL costs were. 1316.50 :-O :help:
4x Trojan T105 $658.56 (I have 7 12v car/marine batteries of various sizes for cores) donated by friends :)
Promariner 12/50p $394.56
Promariner remote $75
BUSBARS - 4-Post Power Distribution Block - 5/16" Black $21
Stinger SPF5660 Shoc-Krome Maxi Fuse 60 Amp 3-Pack $6.99
Ancor 252140 Butt Connectors (6-Gauge, 2-Pack) $7.43
Ancor 242245 Marine Grade Tinned Copper Lugs (6-Gauge, Size 5/16 Screw, 25-Pack) $25.58
3 of Bussmann HHX In-Line MAXI Fuse Holder with Cover - 32V/60A - #6 Wire Leads, 1 Pack $25.11
1 AWG Battery Cable Tinned Marine Grade Wire Red&black by the foot 8ft x 2 @ 27.52 x 2 = $55.04
10/3 AWG Marine Grade Wire Tinned Boat Cable Flat by the ft 5ft $6.50
6 AWG Battery Cable Tinned Marine Grade Wire Red&black by the foot 25ft x2 @ 28.00 x 2 $56.00
8Awg @ 12ft plus lugs at WM $20.42
Thanks again, and would love to post some pics but needs some help there.
paboater76
Postby paboater76 » May 13th, 2018, 9:18 pm
MakinTime
Vessel Info: Carver 3607 MakinTIme
Glastron MX175 MakinTimeToo
Has thanked: 52 times
Been thanked: 31 times
Postby MakinTime » May 14th, 2018, 6:34 am
Nice clean install looks good!
paboater76
Postby paboater76 » May 19th, 2018, 9:31 am
For those with the Trojan's and the Vic monitor, what are you setting you charged voltage too?
paboater76
Postby paboater76 » May 19th, 2018, 9:35 am
Return to “Electrical”
