Kohler generator for dummies, questions
Re: Kohler generator for dummies, questions
- Keith S
- Vessel Info: 2005 38 Super Sport
- Been thanked: 21 times
The 7.5R was a real workhorse in its day, but obsolete and ancient today. As others have stated, does the fuel pump run? Disconnect the discharge and be sure it is moving fuel. The cube pumps actually have a circuit board in them and don't like reverse polarity. If the pump is working, rap the bowl of the carb, they float could be stuck.
It needs to be mentioned that the fuel pump must be USCG approved for ignition protection. It also is a requirement that the pump can only run when the engine is running, so it needs to be wired through an oil pressure switch. It also must be mounted within 12" of the engine and all fuel lines you install should be USCG approved.
- StDuckie
- Vessel Info: 1991 3607 Aft Cabin Cummins 6BTA
- Has thanked: 29 times
I read that a solenoid automatically recognizes that genset is on and switches off the shore power…is that correct?
I have disconnected the shore power cords and when I attempt to start genset it starts momentarily, then shuts off and there’s a noise coming from inside the main electrical panel…HELP!
If you can't get it to keep running after a few tries then you have another problem.
Let us know.
- Been thanked: 1111 times
Check oil and oil pressure on the genset. When was the last time the impellor was replaced? Is there water flow through the genset? When was the last time it was run?
Once the generator stays running, then you can concentrate on the relays if you are having trouble getting power to either or both of the AC power panels.
- buster53
- Has thanked: 10 times
- Been thanked: 285 times
Genset shut down. Restarted and ran for a minute or two before shutting down again. This happened several times and would only run a minute or so. After 5-6 restarts, it would only run for a few seconds before shutting down. Just bought this boat in March and haven't had any problems until today.
I checked to make sure my oil level was good. What's next...replace fuel filter maybe? Any other suggestions?
- buster53
Correct me if I'm wrong...doesn't Carver usually use the port tank for the genset?
- Has thanked: 602 times
- Been thanked: 1310 times
Lots of boats have port side, you will have to trace yours out, mine has both tanks with a valve to control.....if there is an antisiphon valve at the tank in your gen fuel line might be worth checking first. Changing the fuel filters won't hurt. You could also run it from an external tank to eliminate the boat system as a problem....thats kinda the way I might approach it.....good luck man.
- buster53
Users browsing this forum: No registered users and 9 guests
