AC discharge
- Grafunkus
- Captain
- Vessel Info: 1982 33' Carver Mariner
1985 3607 Carver Aft Cabin - Location: Manitoba, Canada
- Has thanked: 63 times
- Been thanked: 32 times
AC discharge
Re: AC discharge
- Grafunkus
- Captain
Re: AC discharge
- buster53
- Has thanked: 10 times
- Been thanked: 285 times
Re: AC discharge
Make sure the thru hull for the pump is open. Don't ask where it is located...you need to get a flashlight and spend some time in the bilge. Locate all thru hulls and identify what they are used for. Find all bilge pumps. Find your water system pump. Find your sump pumps and when you do, clean them out.
Now that you have confirmed your thru hull is open, turn the AC on and adjust the temp either up or down far enough that the compressor turns on. If it turns on and water is pumping you are go to go. If it turns on and no water, it should turn off fairly quickly.
No water...could be a bad pump, blocked thru hull or the pump has lost it's prime.
Yes, the fan will run without water pumping. That is standard operation.
Re: AC discharge
- John Easley
- Vessel Info: Sold a 1986 42' Chris Craft Catalina. Looking for a 1999-2006 530 Voyager Pilothouse.
- Has thanked: 5 times
- Been thanked: 8 times
Re: AC discharge
- RGrew176
- Has thanked: 72 times
- Been thanked: 470 times
Re: AC discharge
- buster53
Re: AC discharge
RGrew176 wrote:On my 3007 the easiest way to prime the seawater pump for the A/C is to take the boat out for a short run. That primes the pump for me.
Every boat is different. The sailboat I used to have....I'd lose my prime just running the boat over to the fuel dock and back. Eventually, I learned to close my thru hull before leaving my slip.
Re: AC discharge
RGrew176 wrote:Source of the post On my 3007 the easiest way to prime the seawater pump for the A/C is to take the boat out for a short run. That primes the pump for me.
Depends on what type of thru-hull they installed. If you have a scoop, then it works great. If you have a flat intake, not so much (although that also depends on placement on the bottom).
Also depends on how high the circulation pump is and what restrictions (hoses, strainers, etc) are in place between the thru-hull and the pump.
- AaHubb
- Vessel Info: '99 404 CPMY
- Has thanked: 15 times
- Been thanked: 61 times
Re: AC discharge
..Aaron
SeaDragon
