Power panel amp question
Blake
Vessel Info: 2002 Carver 350
Has thanked: 6 times
Postby Blake » May 29th, 2018, 9:03 am
Good morning, new owner here.
I have a 2002 Carver Mariner 350. Yesterday I noticed that the main meters are showing 110 v when plugged into shore power, and everything seems to be working.
However, the meters show almost 0 (zero) amps drawn, and also the green lights to show "Shore #1 Safe" and "Shore #2 Safe" do not turn on. I have never noticed if the green lights on the panel ever turned on.
When the a/c kicks on, the amp meter needle moves to show initial draw and then returns to slightly above one amp.
I turned on water pump and did not notice any movement in the amp needle.
Thoughts?
Sorry, here is photo of the panel.
buster53
Vessel Info: 2001, Carver 356
Has thanked: 10 times
Been thanked: 285 times
Re: Power panel amp question
Postby buster53 » May 29th, 2018, 9:11 am
When the AC turned on, did the compressor actually turn or or just the fan?
Your water pump is 12v. It will not affect your amp meter.
Blake
Postby Blake » May 29th, 2018, 9:31 am
Thanks for the water pump info!
Yes, the a/c compressor did kick on and cold air came out.
I expected to see more amps drawn with systems on, and more importantly why no "green" light illuminated.
Postby km1125 » May 29th, 2018, 9:59 am
Can't speak to the "green light" as we don't have that, but good sign is that the red 'reverse polarity' light is not lit!!
Put a large load like a water heater, microwave or even use a portable space heater and turn it on and you should see the amps gauges move. Depending on the size of your A/C unit, it may read anywhere from 5-12A. Your meter may also not be reading entirely accurately. The water pump for your A/C would probably be about 1-2A
Postby bud37 » May 29th, 2018, 11:30 am
If its like ours, we can only see those lights in the dark, very dim....... :beergood:
SanJuanDreamer
Vessel Info: Still Searching
Been thanked: 21 times
Postby SanJuanDreamer » May 29th, 2018, 10:08 pm
As Bud37 said.....
In addition, when I turn on my water heater, I can see a small movement in the AMP meter.
Your setup sounds normal...
JohnS
Vessel Info: 2003 350 Mariner
Has thanked: 39 times
Been thanked: 16 times
Postby JohnS » September 13th, 2021, 6:56 pm
Was there any resolve on this, mine is doing the same thing 2003 350 Mariner
Postby Viper » September 13th, 2021, 8:35 pm
Are you talking about the indicator lamps or the amp meters or both?
Postby tomschauer » September 13th, 2021, 8:39 pm
The green lights are most likely just burnt out from age. Not a big deal. If your meter shows 120v your are good there.
The a/c should be on shore power #2. I cant blow up the pics, but it looks like you have 60amp gauges on what I would guess is a 30 amp feed. So I would try to figure out the scale. Looks like the first number is 20, so the needle wouldn't move very far with one a/c unit running, it should jump to around 10 on start up.
JohnS
Postby JohnS » September 14th, 2021, 7:05 pm
Meters show 120v just like they should but the ammeters do not move at all really even with 2 ac's running.
Return to “Electrical”
