New Boat Owner
- w4283185
- Vessel Info: 1989 25" Carver Mentego
New Boat Owner
Re: New Boat Owner
Hard to say on the issue because they are all wiring a bit differently.
I would first check to see if the battery charger shows any signs of "life" when plugged in. Are there any lights or gauges on it? A pic of the charger would help.
If the charger is working, it could be as simple as a fuse between the charger and the cabin battery (normally called "house" battery).
Do you have two batteries? The charger may only be directly connected to the engine start battery, and you may have to switch a "1-both-2-off" switch to "both" to get the 'house' battery charged... all depends on how they wired the charger.
- Been thanked: 491 times
Re: New Boat Owner
Are you sure you have 120vac in the boat? Check the breaker at the powerhouse on land.
Then your main breaker.
And everything km had to say.
- w4283185
Re: New Boat Owner
I wanted a smaller boat to start my boating experience, but my wife, bless her heart, thought bigger would be better.
- Has thanked: 603 times
Re: New Boat Owner
- RGrew176
- Has thanked: 72 times
- Been thanked: 470 times
Re: New Boat Owner
Hope it ends up being simple since the charger is for all intents new.
Re: New Boat Owner
- buster53
- Has thanked: 10 times
- Been thanked: 285 times
Re: New Boat Owner
What I'm getting at, is you may be turning on the 12 volt breaker for the refrig and it is turning on.
The 12 volt side will have breakers for cabin lights, electronics, water pump, etc.
the 120 volt side will have breakers for battery charger, electric outlets, air conditioning (if you have one)
You may have a breaker on both sides for the refrigerator if it is a combination 12volt/120volt unit.
- w4283185
Re: New Boat Owner
Time to take out on the lake! Wish me luck!
Re: New Boat Owner
Where in "Upper Michigan" are you boating?
