Decelereration stall and no start
- pepmyster
8.1 Volvo Penta
- Has thanked: 487 times
- Been thanked: 206 times
Re: Decelereration stall and no start
- Has thanked: 598 times
- Been thanked: 1281 times
One more...before you pay someone , have a real good look around at all your connections, grounds etc and don't forget the back of the ignition switch, I think that has been mentioned but still deserves repeating....good luck man.
- Has thanked: 78 times
- Been thanked: 1093 times
What do the "two beeps" mean? There must be some checklist that the ECU does before it does the "two beeps" if you normally get those beeps before you start.
- pepmyster
8.1 Volvo Penta
- pepmyster
8.1 Volvo Penta
- Been thanked: 1180 times
Always carried 2 spares on board when I had mercs. Found out the Ford Windstar version actually are the most reliable as they never did fail. Not sure what style the Volvos take though. Sounds like you are right on track.- pepmyster
8.1 Volvo Penta
That being said I do not know which one would work on the Volvo application however if numbers are the same then the chances are pretty darn good.
Users browsing this forum: Jskhome62 and 14 guests
