No power (electrical) 1996 454 Crusader XL TBI
390Express
Has thanked: 141 times
Been thanked: 15 times
Re: No power (electrical) 1996 454 Crusader XL TBI
Postby 390Express » June 12th, 2018, 7:28 pm
km1125 wrote:Source of the post
390Express wrote:Source of the post When I turn on the ignition switch on the panel for the starboard motor, I get no warnings at the panel or at the dash, and the motor starts with no issue at the helm or by jumping the starter.
When I turn on the ignition switch on the panel for the port motor, I get no warning at the panel, but I do get a "V-Drive" warning light at the helm.
But then you say:
" The boat doesn't have a key, it just has an "ignition" button"
I"M CONFUSED! Do you have a separate "ignition switch" and an "ignition button"??
Do you have gauges? Does anything happen (even a flicker) on the gauges when you turn on the "ignition switch" for each engine"
There is an ignition switch on the panel in the cabin, and an ignition button at the helm.
Weird issue. I have 12v on both sides of the engine breaker 50 amp reset, 12v on both sides of the 10 amp reset, no power to the ECU TBI breaker, and no power to the fuel pump breaker.
I also have no power to the 1 terminal (red battery terminal) on the 9 pin. The 9 pin feeds the motor, correct?
When I push the ignition button, the voltage meter drops to accommodate the draw for the starter, same as the working starboard motor. No other gauges move, same as the working starboard motor. The only odd thing I see different, motor to motor, is that the synchronizer pegs to the port motor when I push the “ignition off” button, but I have no reference, the ignition off button for the starboard side isn’t working.
Postby bud37 » June 12th, 2018, 7:43 pm
So can we catch up a bit....seems to me that when you push the start button , the engine turns over but there is no signal to the TBI or ignition.....is that correct so far ??
Is there sound from the fuel pump ( working )....only when you push the start button..
The other question, does the start button work when the panel switch is off ??
390Express
Postby 390Express » June 12th, 2018, 7:47 pm
bud37 wrote:Source of the post So can we catch up a bit....seems to me that when you push the start button , the engine turns over but there is no signal to the TBI or ignition.....is that correct so far ??
No power to the fuel pump either. Only time I had power to the fuel pump is when I ran a hot to it. There is a 50a main engine breaker, a 10a "ECU breaker, a 10a fuel pump breaker, and a 10a ECU/TBI breaker. (does anyone know why the ECU has two breakers?) The 50a engine breaker and top 10a ECU breaker both have 12v both sides, the fuel pump breaker and bottom ECU/TBI breaker have no power.
Postby bud37 » June 12th, 2018, 7:56 pm
Try continuity checks across those breakers....no power to the ecu and fuel pump seems to be the issue here.....shut power off and take the breakers apart and have a good look and check continuity.
390Express
Postby 390Express » June 12th, 2018, 8:11 pm
bud37 wrote:Source of the post Try continuity checks across those breakers....no power to the ecu and fuel pump seems to be the issue here.....shut power off and take the breakers apart and have a good look and check continuity.
Breakers are all good.
Postby bud37 » June 12th, 2018, 8:19 pm
Do you have the engine side wiring diagram?. Work back ( continuity ) from those breakers that don't have power to them when the button is pressed.
390Express
Postby 390Express » June 12th, 2018, 8:44 pm
bud37 wrote:Source of the post Do you have the engine side wiring diagram?. Work back ( continuity ) from those breakers that don't have power to them when the button is pressed.
There is no power to the excite wire for the relay inside that breaker box.
Postby bud37 » June 12th, 2018, 8:53 pm
OK...now when you press the start button does the starter solenoid make....then you should have a signal to the starter then power back to the breakers.....the neutral switch is in this line I believe ( check continuity thru it )...hard to think about when not there or looking at a schematic.....that power also goes to the alt I believe....do you have this hooked up? Gotta get power to those two breakers...ECU and fuel.... Holy s... wheres the tylenol.
Geez I don't know if this a help or not....
Postby bud37 » June 12th, 2018, 9:10 pm
Is this close for you......not saying it is correct but all I could find.
Edit....not applicable in this case, please ignore.
Postby tomschauer » June 12th, 2018, 9:46 pm
Just checking to be sure....
If you are checking continuity /vs voltage, you need to remove the wires from one side of the breaker or switch. Otherwise you will always read continuity through the breaker or switch via the end device to ground unless the end device has failed.
