Decelereration stall and no start
pepmyster
8.1 Volvo Penta
Fresh water boating
Has thanked: 492 times
Been thanked: 210 times
Re: Decelereration stall and no start
Postby pepmyster » June 12th, 2018, 6:13 am
I looked at the image and they do not look the same. The Merc is a plunger style.
Postby Viper » June 12th, 2018, 6:56 am
Unfortunately the track record for parts when used in cars can't be used as a benchmark for longevity when the same part is used in a marine application, it's a totally different duty cycle and set of conditions. The IAC works more in a car than it does in a boat, and doesn't get laid up for half the year like it does in northern climates. Like any moving components, non-use kills them faster. Add to that the bad practice of spraying storage fluid into the throttle body for winter storage as an easy way of fogging the engine and it's no wonder they fail.
Postby Midnightsun » June 12th, 2018, 8:12 am
I agree however in the case of the IAC I pointed to for the merc they fail horribly. I went through 4 in no time and these were the Merc originals at $150 a pop. Finally decided to go with the Ford equivalent ($40) which never failed me and to date the new owner has put on an additional 400hrs and still doing great. This may be an exception to the rule.
Postby Viper » June 12th, 2018, 3:55 pm
I also think manufacturing has taken some shortcuts. I went for years just replacing the odd one here and there but it seems that the last couple of years I've been replacing them quite often. It hasn't however been on units that I've replaced before so I'm talking original equipment. It just seems like last year and the year before were the years of the IAC for me. Probably replaced a dozen in two years which is a precedent at my end. Will the new ones last as long?...hard to tell but something tells me that like everything else, they don't build ANY brand like they used to.
pepmyster
8.1 Volvo Penta
Fresh water boating
Postby pepmyster » June 12th, 2018, 9:02 pm
I recieved my parts, IAC and plugs. At least the IAC has a warranty of 1 year. I'll give updates on the replacements soon. Thanks to all who have chimed in.
pepmyster
8.1 Volvo Penta
Fresh water boating
Postby pepmyster » June 16th, 2018, 8:08 am
Sooooooo, The other owner said that the other owner replaced the plugs at 600 hours, WRONG! The plugs were the original AC Delco from the factory. They are now replaced with Denso Iradium plugs, IT16. Also, replaced the Starboard IAC , started the motors, they purrrrred. Did the sudden idle drop, beautiful. Now to start to learn how pilot this vessel!!! Thanks for all the input!
Postby Midnightsun » June 16th, 2018, 9:22 am
Glad to see you got her all sorted out. Now get out there and enjoy her. :captain:
Been thanked: 1111 times
Postby km1125 » June 16th, 2018, 11:40 am
Did the plugs still have paint on them? That's the only way I'd say to determine if they were original. In my first boat I replaced plugs with the exact same type as the manufacturer had installed "just in case it made a difference".
pepmyster
8.1 Volvo Penta
Fresh water boating
Postby pepmyster » June 17th, 2018, 8:17 am
Yes, painted right from the factory. 750 hours on them.
Been thanked: 1310 times
Postby bud37 » June 17th, 2018, 9:48 am
pepmyster wrote:Source of the post Sooooooo, The other owner said that the other owner replaced the plugs at 600 hours, WRONG! The plugs were the original AC Delco from the factory. They are now replaced with Denso Iradium plugs, IT16. Also, replaced the Starboard IAC , started the motors, they purrrrred. Did the sudden idle drop, beautiful. Now to start to learn how pilot this vessel!!! Thanks for all the input!
Thanks for posting the resolution.....good its working right........ :beergood:
