Steering not working on the 3207
jwrape
Topic author - Deck Hand
- Vessel Info: 79' Carver 28 Mariner Twin Pleasurecraft 302's (For Sale $12,300)
85' Carver 3207 Aft with Mercury 5.7L - Been thanked: 1 time
Can someone give me some pointers to where the reservoir is located and what fluid to use and anything else I might need to do to get the air out of the system as well.
- Ramsport47
- Has thanked: 72 times
- Been thanked: 59 times
Re: Steering not working on the 3207
T-Merc 350 Mag MPI (300hp)
jwrape
Ramsport47 wrote:Likely, it has plenty of fluid in it. There is a reservoir in the aft cabin, somewhere along the transom, that also needs to be pressurized (with a bicycle pump) to between 20 and 30 PSI. There is a gauge on top of the reservoir so you put enough air in. If it leaks back out, there is a leak somewhere in the system. We have seen them lose air pressure from sitting over the winter or longer storage times. The reservoir should be relatively centered on the transom, so look in the aft head first, then migrate to under the berths.
I believe that is what is behind the Port side bed where the drawers are. I have removed the drawers and seen something like that behind them.... I'll look on Friday when I'm out there.
- Been thanked: 491 times
The hynautic website has the procedure on their website. I had to do the same on my 87 3697 - when I bought it, the reservoir was non-existant - somebody stole it.
jwrape
waybomb wrote:And you'll probably have to perform a bleeding operation which is turning the wheel in one direction a ridiculous amount of turns, like 60 or something like that, and then the same in the other direction.
is it self bleeding by turning the wheel?
I'm going to search hynautic now
Ingenious.
- iceman3500
- Vessel Info: 1987 Carver 3207
Thanks, Iceman
I have never taken one apart, but there's lotsa parts in there. Before you attempt it yourself, you may want to read up on it. Looks straight forward and probably worth a try. Ebay tends to have parts - do a "hynautic" search.
jwrape
- AaHubb
- Vessel Info: '99 404 CPMY
- Has thanked: 15 times
- Been thanked: 61 times
SeaDragon
Users browsing this forum: No registered users and 43 guests
