Sporadic Alarm on take off 326 AFT
Marty
Vessel Info: 2000 326 AFT Cabin
Has thanked: 16 times
Been thanked: 9 times
Re: Sporadic Alarm on take off 326 AFT
Postby Marty » July 20th, 2018, 9:34 am
Absolutely if any belt work is involved I’ll hire someone to do it.
Has thanked: 469 times
Been thanked: 1765 times
Postby Viper » July 21st, 2018, 6:34 am
Marty, can you post the engine serial number?
Marty
Postby Marty » August 14th, 2018, 6:12 pm
Sorry just doubling back on this and had the impeller replaced (which was in decent condition) and the alarm still sounded on take off???
DCharles
Vessel Info: 2001 Carver 326
Postby DCharles » September 2nd, 2018, 10:25 am
I had the identical issue. It’s a simple fix. Pull the hose off the inlet side of the trans heat exchanger and remove the pieces of old impeller pieces. You can use a shop vac also if you pull both hoses of the heat exchanger and put your hand over the other side, creating more suction
I’m an automotive tech and discovered this quickly on my boat and then had to do it on four other boats (Searay-Fourwinns-Cruisers)that had alarm issues that just had work done on. Can’t believe techs dont clean these after aver impeller replacement. The pieces have to go somewhere!!
