Forward ac unit
- pepmyster
8.1 Volvo Penta
- Has thanked: 492 times
- Been thanked: 210 times
Forward ac unit
Thanks in advance, Andrew.
Re: Forward ac unit
- Has thanked: 602 times
Re: Forward ac unit
Re: Forward ac unit
- pepmyster
8.1 Volvo Penta
Re: Forward ac unit
Re: Forward ac unit
pepmyster wrote:Source of the post As Hans knows me, the first week I bought the boat, I removed the ac filters (grilles) and vacuumed all around. The flow of air coming out of the vents is fantastic. The only air this receives is from under the lower front drawer area in front of the bed. Not enough if you ask me. The only solution I see is installing a high volume fan directed at the evap itself.
Prop open the bed or whatever you can to increase the air intake and see if the extra opening solves your issue. If not then you may be low on freon.
- pepmyster
8.1 Volvo Penta
Re: Forward ac unit
Re: Forward ac unit
Improper operating refrigerant pressures, too low: surprisingly to the novice, too little refrigerant in the system can actually drop the temperature in the cooling coil below its normal operating range; that's why we mention at FROST BUILD-UP on AIR CONDITIONER COILS that a cause of coil frosting in the air handler might be an early sign of a refrigerant leak.
See here.https://inspectapedia.com/aircond/Refri ... charge.php
- pepmyster
8.1 Volvo Penta
Re: Forward ac unit
