1998 Props on 405
Been thanked: 646 times
Re: 1998 Props on 405
Postby g36 » August 11th, 2018, 10:20 am
Nice! lookin good
Has thanked: 598 times
Been thanked: 1281 times
Postby bud37 » August 11th, 2018, 11:49 am
Good stuff , thanks for posting the resolution.....boat is looking good....... :down:
Has thanked: 469 times
Been thanked: 1765 times
Postby Viper » August 11th, 2018, 12:02 pm
:down: :down:
Has thanked: 78 times
Been thanked: 1093 times
Postby km1125 » August 12th, 2018, 10:07 am
The boat looks great!! I think 23 is pretty reasonable expectation for that size boat with those engines. I have a 36' with 7.4L Crusaders and max out around 28 MPH. I'm sure I'm pushing a lot less water and lifting a lot less weight!
Been thanked: 601 times
Postby tomschauer » August 17th, 2018, 9:51 pm
sounds good. We tested a 405 with the 385hp 502's and got to 26 WOT, so it sounds like you have it!
Serendipity
Vessel Info: 1998 Carver 405
Has thanked: 234 times
Been thanked: 38 times
Postby Serendipity » August 18th, 2018, 7:09 am
It was indeed bad injectors as you mentioned Tom.
Serendipity
Postby Serendipity » August 29th, 2018, 10:43 pm
So here is an update.
I got 4400 rpms and 25 mph in 2 ft waves, at the end of my 400 mile trip.
This happened about 2 miles from the marina in the Gulf off the Coast of Mississippi. I put 45 hours on the boat and it had 365 hours when I purchased it. So the port injectors need replacing like I did for the starboard as I am sure they are original.
I am very pleased with these specs. I put 45 or so hours on the generator as well. It ran when I wasnt plugged into shore power. All in all, the boat did great to be a 20 year old dock queen averaging 18 hours a year. I am happy so far with my purchase.
Postby tomschauer » August 30th, 2018, 12:06 am
if the port engine runs fine, I personally wouldn't be in a rush to replace the injectors. If you continue to run it regularly, they will most likely be fine.
Ethanol sludges up when sitting unused for extended periods, but cleans the heck out of everything, including the injectors when its fresh.
Postby g36 » August 30th, 2018, 9:35 am
sounds like you had a good trip with no big issues. boats like to be used :down:
Been thanked: 468 times
Postby RGrew176 » August 31st, 2018, 3:21 am
Nice report on your trip. Glad to hear that you had a good and safe trip. Keep us updated on your progress.
2022 Stingray 182 SC
