Electric head questions
- chpsk8
- Has thanked: 27 times
- Been thanked: 76 times
Just playing around I noticed that the aft head pumps way more water than the front head. I also noticed that neither head had any water sitting in the bowl. The flush button on the wall did just that, flushed. Is there a way to add water to the bowl? It all just flushed away.
I'm thinking that I might need to rebuild the impeller on the front head since I could barely get any water for flushing. I didn't see any obvious branding to tell me what it is. Anyone have a path I can start from?
Thanks for the help!
Re: Electric head questions
If they are fresh water flush, you should have a red flush button and a rocker switch below it that is labeled flush on one side and fill on the other.
- chpsk8
https://www.yachtworld.com/boats/1995/Carver-355-Aft-Cabin-3097653/#.W3ogAihKg2w
This isn't the boat, but that's the head and the button that it has. One for the fan (which my 9 year old was happy it was so close to the bowl btw). The other one is the flush button.
Raw water heads will have two hoses to the motor and pumps at the base of the head. Fresh water will on have one outlet hose. The inlet water will go directly to the rear of the bowl.
- chpsk8
I'll get some better pictures once I own it. Looks like I'm in for some work regardless, just needs to figure out what brand I have.
- Been thanked: 490 times
The pump actually has two parts - the pump that lifts the water up and a pump that macerates and sends stuff to the tank. The pumps share the drive shaft.
I had the same problem. I pulled the thing out, took it completely apart, and rebuilt it with an upgrade kit. Works fine now.
- chpsk8
- buster53
- Has thanked: 10 times
- Been thanked: 285 times
I did this 4 years ago or so, so I don't remember what exactly changed. I believe it was on the black water side and when I compared the old to new, the parts were different.
Before you take it apart, run a bunch of water through it.
- chpsk8
I'll get the model number and get some parts on order.
Beats trying to access the front of the starboard motor!
