swinging at anchor
- Crowbar
- Vessel Info: 1987 Carver Voyager- twin 230 hp gas
swinging at anchor
- jsinton
- Vessel Info: '79 28ft Voyager w/ 100KW BMW Marine Diesel.
- Been thanked: 4 times
Re: swinging at anchor
- RGrew176
- Has thanked: 72 times
- Been thanked: 470 times
- CaptBob
- Vessel Info: Shopping....
- Been thanked: 33 times
So that begs the question, as I've assumed the swing was a product of our windage (mostly) and current, will a snubber reduce the swing, and why? I tie my chain to the cleat with a chain stay to get the stress off the windlass, but I have no snubber in play anywhere. If it would help, i'm off to amazon to find one!tomschauer wrote:Source of the post with a single bow anchor and no snubber system, your boat will swing with the wind and the current. Point it where you want it to be and deploy a stern anchor.
More Nautiville 2004 Carver 360 Sport Sedan
A little less Nauti 2008 SeaDoo 150 Speedster (Admiral could not live without a jet boat....
)Nautiville 2005 Cruisers 280 CXi *Sold*
Nautitown 2012 SeaDoo 180 SP *Sold*
- CaptBob
km1125 wrote:Source of the post Tie another line to your rode and pull it offcenter to a side cleat. The boat is swinging like a pendulum or a rocking chair. You want to disturb the "even-ness" and let the wind or current favor one side or the other rather than be equal on both sides.
Well duh. That makes so much sense , I am now annoyed that I didn't think of that.
i am almost hoping for some wind this weekend so I can try it out! In hindsight, we have already proved that, anytime we have someone rafted on us, we do not swing. When they leave, off we go! So apparently either tie the rode or another boat to the side to reduce swing!
- pepmyster
8.1 Volvo Penta
- Has thanked: 492 times
- Been thanked: 210 times
- thisDave
- Vessel Info: 2003 Carver 570
Twin Volvo D12 650 - Location: Puget Sound
- Has thanked: 1 time
We normally use a bridle on the front cleats. I was able to slow the swing by tying one side of the bridle to a midship cleat, following the suggestion above. I've also tried a 4ft drogue which really slowed the movement, but didnt reduce the arc.
Suggestions? I'm open to new ideas.
- Phrancus
- Has thanked: 16 times
- Been thanked: 136 times
- Contact:
Introducing one side to be pushed more than the other makes sense like described. A water anchor would not help as much as the turning point it still the rear of the boat and you need good current to keep it under pulling pressure.
The snubber to choose the pushing side to the boat by the wind or an added anchor to change the turning point are the solutions I believen. Note: use the rear anchor also to make the profile asymetrical otherwise you still have a changing force to the boat by the wind.
With a bit of trial you can find the most effective cleat to tie the rear anchor to so you get the right air flow through the boat and keep it that way during the stay. I also like it because I can position the shades more effectively when the boat stays put.
