Fresh Water Tank Leak
- ronmar
- Vessel Info: 1993 350 Aft Cabin
- Has thanked: 21 times
- mjk1040
- Been thanked: 248 times
Re: Fresh Water Tank Leak
- Has thanked: 603 times
Regarding the teflon tape,I would not use it here, just a paste type thread sealant for the plastic fitting you are using....the reason being , if you were to put too much tape and then overtightened you will stand a very good chance of splitting the tank threaded fitting...FYI you can even split brass fittings this way.Good luck with it , be careful and all will be fine.........
I'm confused about this part "tube exits tank straight out bottom end and threads into an elbow that connects to main water lines"
Use your phone to take pictures of everything you're working on. Gives you some good "before" and "after" pictures for down the road, but very helpful when you're in the middle of a project and not near the boat. Years ago I bought a cheap digital camera and left it on the boat, and had several SD cards to shuttle back and forth to hold the pics while I was working on projects. Now I just use the phone.
- ronmar
mjk1040 wrote:Source of the post I can only guess but would bet on 1/2". And yes I would use Teflon tape on the fittings.
Thanks, going back Friday to tackle. Appreciate the help
- ronmar
bud37 wrote:Source of the post When you get it apart, have a close look to make sure it is the fitting that is cracked and not the tank at the threads.
Thanks for the tips> Always appreciate plumbing help!
Contrary to most of the above, I personally use a bit of 100% silicone on the threaded fittings, and make sure to let it cure for a few hours before adding water. This way there is no danger of cracking the tank due to too much tape, and the silicone will seal better than pipe dope (thread sealant).
- ronmar
tomschauer wrote:Source of the post For some reason, many of these boats use 5/8 ID hose, but 1/2 NPT threads.
Thanks!
- ronmar
