325 Carver Marine Air Passport II
nazinteck
- Vessel Info: 1997 325 Carver Aft with twin Gas TB350 XLi engines
- Has thanked: 16 times
- Been thanked: 5 times
I purchased my 325 Carver in FEB 18. I immediately noticed upon acceptance what appeared to be an intermittent water flow problem while operating my two AC units. In the late spring I called for heat and in the summer it was strictly AC. I noticed some intermittent water flow stoppages during either operation. I have read that some units have relays working with the compressor to cycle on and off. I was never convinced my system was designed to do that. Most other Carver's in my marina seem to have constant water flow while the heat or AC system is on?
My two Passport II controls seem to work well. However I NO longer have water running through either unit and I do know my pump is not physically operating while wired into the system. When I located the Marine Air wiring junction box which appears to contain all the wiring for the two units, I noticed the previous owner had twist tied a "spare" 110V molded chord with exposed ends in what appears to have been an attempt to troubleshoot a pump? The spare chord was twist tied to the water pump 110v cable??? The surveyor apparently never noticed that? Anyway I suspect the pump is faulty and I will start troubleshooting the system this weekend as neither unit works right now but the controls do call for AC and both systems seem to initially fire up normally. Both units operate for about a minute and shut down as water is NOT pumping and I suspect that is what the system is looking for? I have removed the strainer basket and all is clear on the water line side. My plan is to start by disconnecting the pump wiring at the j-box and connect it to 110v to see if the pump works outside the controls. Any other suggestions are greatly appreciated.
Re: 325 Carver Marine Air Passport II
nazinteck
This may be normal as my water pump works only when the demand for heat or cool is active. The air circulation fan is in continuous operation which is set to auto on mine. In other words, if I set the AC to 72F and the temperature drops to 72F, their is no more demand and the water pump shuts down. Once the temperature rises above the 72f set point, the pump will turn on.
As mentioned, check for voltage at the pump. To do so, make sure you set the AC down low so as to create a demand which will send 110v to the pump.
nazinteck
if it hooks up to the control box as it should, check if you have output at the terminal block for the pump while the AC is turned on. If you don't, the function is controlled by either a relay or driver. If it's just that component that has failed and you're handy, you can probably source it at an electronic parts supplier if you pull a number off the part. These are usually located right above the terminal block where the connections are made. Relay pin configurations are universal and you should be able to find the pin layout and their function on line for testing purposes. The pin codes should be stamped or labeled on the relay.
nazinteck
nazinteck
