Carver 350 engine meter
- Blake
- Vessel Info: 2002 Carver 350
- Has thanked: 6 times
Re: Carver 350 engine meter
Since the tach works I am ruling out the sender as the cause. Thinking the module may be the cause.
- Has thanked: 602 times
- Been thanked: 1310 times
I would try disconnecting it to see if the hour meter issue goes away.
I am not sure if these modules are still available. Mine failed and I replaced it with a flowscan.
- pepmyster
8.1 Volvo Penta
- Has thanked: 492 times
- Been thanked: 210 times
Blake wrote:Source of the post Thanks!! I know it doesn’t make sense but when synch gauge works the engine hours works.
Heh there Blake , have you found the replacement part yet ? I am thinking to replace mine as well.
- Been thanked: 654 times
black box
https://greatlakesskipper.com/beede-boa ... 7sQAvD_BwE
- denpooch
- Has thanked: 85 times
- Been thanked: 89 times
A couple of weeks ago, I noticed more hours on the starboard engine. I thought it was caused by something mentioned in an earlier post regarding the key in the 'on' position. I then noticed that there is a small blinking 'h' in the meter window when the engines are running (per Viper comment). I discovered that the hours were not synced because the port side is neither blinking nor registering hours. The port meter simply stopped working. The tachs seem to be accurate.
My sync indicator has never run properly, bouncing all over the place, and I wonder if this caused a short of some kind. I spoke with Beede and they sent some wiring diagrams (for a module) but I don't think it's a match for my system. I am at a standstill.
The hours are being registered on only one engine (stbd) and it will take some explaining should I decide to sell at some point in the future.
I have included photos of rear gauges, both sync and port tach.. Any suggestions would be very much appreciated.
Users browsing this forum: No registered users and 48 guests
